BT.com
Wishlist
Asus GeForce GT 630 902MHz 2GB PCI-Express 2.0 HDMI Silent
Delivery
Standard Due date unavailable
Great value graphics with superior stability and 3D gaming
Every PC deserves great graphics. The NVIDIA GeForce GT 640 graphics card taps into the powerful GeForce architecture to deliver premium multimedia performance and reliable gaming- every time.
  • Pump up graphics performance with Super Alloy Power delivering a 15% performance boost, 2.5 longer lifespan and 35°C cooler operation
  • Silent passive cooling means true 0dB - perfect for quiet home theater PCs and multimedia centers
  • GPU Tweak utility helps you modify and tune clock speeds, voltages, and fan performance via an intuitive interface
0dB Silent Cooling: Perfect for building a hushed HTPC
Exclusive ASUS-designed heatsinks with large surface areas effectively cool graphics cards passively so absolutely no sound is produced while running - perfect for high definition and silent home theater PCs and multimedia centers.
Super Alloy Power: Enhanced durability and cooling
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors.
GPU Tweak: Real-time intuitive graphics tuning
  • Monitoring widget provides real-time detailed multi-parameter info
  • Automatically checks and updates drivers and BIOS versions
  • Get detailed specs and actual card status with GPU-Z
2GB GDDR3 Memory
On-board memory for the best gaming experience & the best resolution.
Graphics GPU Features
  • Powered by NVIDIA® GeForce® GT 630
  • NVIDIA® Adaptive V-Sync: Get more than just faster frame rates. Get ultra-smooth gaming every time with NVIDIA® gaming innovation Adaptive Vertical Sync. This technology dynamically adjusts vsync to current frame rates for maximum playability.
  • NVIDIA® PhysX™: Play games with advanced effects such as blazing explosions and lifelike characters with 10X faster switching between graphics and physics processing, enabling more complex effects to be rendered in real time.
  • DirectX® 11: DirectX® 11 GPU-accelerated tessellation allows more detailed geometry to be packed into a scene, allowing characters to be rendered with cinema-quality detail.
  • Low Profile Design: ASUS low profile HTPC and multimedia-focused graphics cards are optimized for smooth 1920x1080 streaming and Blu-ray 3D.
I/O Ports Highlight
  • 1 x Native HDMI
  • 1 x Native Dual link DVI-D
  • 1 x D-sub
ASUS GT630-SL-2GD3-L graphics card - GF GT 630 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce GT 630
2 GB DDR3
Core Clock
902 MHz
CUDA Cores
384
Effective Memory Clock
1.8 GHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
DVI-D (dual link) ¦ VGA ¦ HDMI
API Supported
DirectX 11
Fanless
3 cm x 13.7 cm x 6.9 cm
Microsoft Certification
Compatible with Windows 7
Graphics card - low profile - fanless
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
902 MHz
CUDA Cores
384
Max Resolution
2560 x 1600
API Supported
DirectX 11
Native HDMI, Silent Cooling System (SCS), ASUS 0-dB thermal solution, Nvidia PhysX-Ready, Super Alloy Power technology, Adaptive V-Sync, HDCP
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.8 GHz
Bus Width
64-bit
Additional Requirements
Adjacent PCI slot
75 Watt
Software Included
Drivers & Utilities, ASUS GPU Tweak
3 cm
13.7 cm
6.9 cm
Scroll to top
