BT.com
Wishlist
Asus GeForce GT 630 810MHz 2GB PCI-Express HDMI
Delivery
Standard Due date unavailable
Asus GT630-2GD3 Gigantic 2GB! ASUS GT 630 delivers efficient multimedia and gaming performance
  • Pump up graphics performance with Super Alloy Power delivering a 15% performance boost, 2.5 longer lifespan and 35°C cooler operation
  • Dust-proof Fan design increases particle resistence and extends card lifespan by up to 25% longer than reference.
  • GPU Tweak utility helps you modify and tune clock speeds, voltages, and fan performance via an intuitive interface.
ASUS GT630-2GD3 is equipped with Super Alloy Power which reaches 15% performance increase, 2.5 times longer product lifespan and 350C cooler operation. Dust-Proof Fan design additionally dissipates heat efficiently while expending lifespan by 25%. Moreover, ASUS GT630-2GD3 comes with exclusive GPU Tweak utility, which allows users to modify clock speeds, voltages, and fan performance.
Specification
  • Graphics Engine GeForce® GT630
  • Bus Standard PCI Express® 2.0
  • Video Memory 2GB DDR3
  • Engine Clock 810 MHz
  • CUDA Cores 96
  • Shader Clock 1620 MHz
  • Memory Clock 1820MHz (910MHz DDR3)
  • Memory Interface 128 bit
  • DVI Max. Resolution 2560 * 1600
  • DSub Max. Resolution 2048 * 1536
  • D-sub Output YES X1 (Native)
  • DVI Output YES X1 (Native DVI-I)
  • HDMI Output YES X1 (Native)
  • HDCP compliant YES
  • Software Bundled ASUS Utilities & Driver
  • Dimension The card size is 7.6" x 5.12" x 1.18" inches
ASUS GT630-2GD3 graphics card - GF GT 630 - 2 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce GT 630
2 GB DDR3
Core Clock
810 MHz
CUDA Cores
96
Effective Memory Clock
1.82 GHz
Shader Clock
1620 MHz
Memory Interface
128-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
DVI-I (dual link) , VGA , HDMI
API Supported
DirectX 11
19.3 cm x 13 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
810 MHz
CUDA Cores
96
Shader Clock
1620 MHz
Max Resolution
2560 x 1600
API Supported
DirectX 11
Nvidia CUDA technology, Nvidia PhysX-Ready, Super Alloy Power technology, Dust-proof fan , HDCP
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.82 GHz
Bus Width
128-bit
Software Included
Drivers & Utilities, ASUS GPU Tweak
19.3 cm
13 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* good card
Reviewed by jay on 18/03/2014
Well to be honest i have been using a gforce gtx 260 for the last 5 years and its been an awesome card this new asus gt630 is the same preformance if not better so well happy with it.
as for noise its no louder than my mini typhoon cpu fan :)
1* Far too noisy
Reviewed by Anonymous on 20/10/2012
This video card is far far far too noisy. I expected more from Asus. I will not buy asus cards again as I can't rely on them producing workable goods.
Just don't buy. A 630 is hardly a major powerhorse. There is no reason at all for it to be noisy. This card is just a joke. I have to remove it and bin it.
Scroll to top
