BT.com
Wishlist
Asus GeForce GT 610 810MHz 2GB PCI-Express 2.0 HDMI Low Profile
Delivery
Standard Due date unavailable
PLEASE NOTE: These Graphics Cards Do NOT Ship With Low Profile Brackets From April 1st 2013
ASUS GT610-SL-2GD3-L Gigantic 2GB on a low profile design!
The newly arrived ASUS GT610-SL-2GD3-L ships with 0dB silent thermal and low profile design with low profile bracket bundled that could fit end user's mini home theater pc and offer the best home theater enjoyment. Especially, its 2GB massive memory size can provide the best gaming experience in great resolution. Furthermore, ASUS GT610-SL-2GD3-L built with Super Alloy Power technology for enhanced durability. Besides, ASUS GT610-SL-2GD3-L also comes with exclusive GPU Tweak utility, which allows users to modify clock speeds, voltages, and fan performance.
  • 2GB massive memory size for smooth gaming experience
  • Exclusive 0dB thermal design dissipates heat efficiently without any noise
  • Super Alloy Power blends selected elements under ASUS exclusive formula, resulting in a 15 % performance increase, 2.5 times longer product lifespan and 350C cooler operation
  • GPU Tweak utility allows you to tune graphics card performance and check card status via an intuitive interface
  • Low profile design with low profile bracket bundled
Spec
  • Model GT610-SL-2GD3-L
  • Graphics Engine GeForce GT610
  • Bus Standard PCI Express®2.0
  • OpenGL OpenGL® 4.2
  • Video Memory 2GBDDR3
  • Engine Clock 810MHz
  • Memory Clock 1200MHz (600MHz DDR3)
  • Memory Interface 64bit
  • RAMDAC 400MHz
  • DVI Max. Resolution 2560 * 1600
  • D-SubMax. Resolution 2048 * 1536
  • D-Sub Output YES, native
  • DVI Output YES, native
  • HDMI Output YES, native
  • HDCP compliant YES
  • Adaptor/Cable Bundled 2X 1-slot LP Bracket
  • Software Bundled ASUS Utilities & Driver
  • Dimension 7.3"x 4.7"x 1.6"
ASUS GT610-SL-2GD3-L graphics card - GF GT 610 - 2 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce GT 610
2 GB DDR3
Core Clock
810 MHz
Effective Memory Clock
1.2 GHz
RAMDAC
400 MHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
VGA , DVI-I (dual link) , HDMI
API Supported
DirectX 11
Fanless
4.1 cm x 18.5 cm x 11.9 cm
Microsoft Certification
Compatible with Windows 7
Graphics card - fanless
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
810 MHz
RAMDAC
400 MHz
Max Resolution
2560 x 1600
API Supported
DirectX 11
ASUS 0-dB thermal solution, Nvidia CUDA technology, Nvidia PhysX-Ready, Super Alloy Power technology , HDCP
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.2 GHz
Bus Width
64-bit
Software Included
Drivers & Utilities, ASUS GPU Tweak
4.1 cm
18.5 cm
11.9 cm
Accessories
£7.23
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£20.25
£39.28
£52.56
Scroll to top
