BT.com
Wishlist
Asus F2A85-V PRO AMD FM2 A85X DDR3 ATX
Delivery
Standard Due date unavailable
ASUS F2A85-V PRO features ASUS USB 3.0 Boost technology. ASUS USB 3.0 Boost technology supports UASP (USB Attached SCSI Protocol). With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased up to 170%, adding to an already impressive fast USB 3.0 transfer speed. ASUS software automatically accelerates data speeds for compatible USB 3.0 peripherals without the need for any user interaction.
ASUS F2A85-V PRO - motherboard - ATX - Socket FM2 - AMD A85X
Motherboard - ATX
Chipset Type
AMD A85X
Processor Socket
1 x Socket FM2
Compatible Processors
Athlon, A8 series, A6 series, A4 series, A10 series
Data Bus Transfer Rate
5 GT/s
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
7 x SATA-600 (RAID), 1 x eSATA-600 (RAID)
USB / FireWire Ports
4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 8 x USB 2.0 via headers)
Max Allocated RAM Size
2048 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Motherboard - ATX
Chipset Type
AMD A85X
5 GT/s
Processor Socket
Socket FM2
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR3
Bus Clock
2400 MHz, 2200 MHz, 2000 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz, 2250 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, AMD Memory Profile (AMP)
Graphics
2048 MB
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Controller
Realtek RTL8111F
Network Interfaces
Gigabit Ethernet
Storage Interfaces
SATA-600 -connectors: 7 x 7pin SATA, 1 x 7pin eSATA - 8 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 / JBOD
1 x PS/2 keyboard / mouse , 1 x VGA , 1 x DVI , 1 x HDMI , 1 x TOSLINK , 4 x USB 3.0 , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x DisplayPort
Internal Interfaces
8 x USB 2.0 , 1 x SPDIF out - header , 2 x USB 3.0 , 1 x audio - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, USB BIOS Flashback, UEFI BIOS, SMBIOS 2.7 support
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, ESD Guards, GPU Boost, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS TurboV, ASUS 6+2 Phase Power Design, Fanless Design Heatsink, AMD Radeon Dual Graphics, Conductive Polymer Capacitors, Dual Intelligent Processors 3, ASUS USB 3.0 Boost technology, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS Fan Xpert 2, ASUS Network iControl, ASUS SMART DIGI+, ASUS USB Charger+, Lucid Virtu MVP, ASUS Remote GO!, Low EMI Solution, Disk Unlocker, AMD Turbo CORE 3.0 technology
I/O back plate
4 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS Auto Tuning, ASUS AI Suite II, ASUS AI Charger+, ASUS Update
Plug and Play, ACPI 2.0a, ErP Ready
30.5 cm
24.4 cm
Limited warranty - 3 years
Scroll to top
