BT.com
Wishlist
Asus F2A85-M LE AMD FMX A85X DDR3 mATX
Delivery
Standard Due date unavailable
This motherboard supports AMD A-series accelerated processor with AMD Radeon HD 7000 series graphics. This revolutionary APU (Accelerated Processing Unit) combines processing power and DirectX 11 graphics in one small, energy-efficient design to enable accelerated performance and an visual experience. It features dual-channel DDR3 memory support and accelerates data transfer rate up to 5 Gtps.
AMD A85X FCH (Hudson D4) is designed to support up to 5 Gtps interface speed and PCI Express 2.0 x 16 graphics. It natively supports 8 x SATA 6 Gbps ports and 4 x USB 3.0 ports. F2A85-M LE brings you the multi-GPU choice of CrossFireX. Expect a gaming style you've never experienced before!
ASUS F2A85-M LE - motherboard - micro ATX - Socket FM2 - AMD A85X
Motherboard - micro ATX
Chipset Type
AMD A85X
Processor Socket
1 x Socket FM2
Compatible Processors
Athlon, A8 series, A6 series, A4 series, A10 series
Data Bus Transfer Rate
5 GT/s
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
7 x SATA-600 (RAID), 1 x eSATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Max Allocated RAM Size
2048 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Chipset Type
AMD A85X
5 GT/s
Processor Socket
Socket FM2
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
2400 MHz, 2200 MHz, 2000 MHz, 1600 MHz, 1866 MHz, 2133 MHz, 2250 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, AMD Memory Profile (AMP)
Graphics
2048 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111F
Network Interfaces
Gigabit Ethernet
Storage Interfaces
SATA-600 -connectors: 7 x 7pin SATA, 1 x 7pin eSATA - 8 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 / JBOD
1 x PS/2 keyboard / mouse , 1 x VGA , 1 x DVI , 1 x HDMI , 1 x TOSLINK , 2 x USB 3.0 , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
6 x USB 2.0 , 1 x SPDIF out - header , 2 x USB 3.0 , 1 x audio - header , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, UEFI BIOS, SMBIOS 2.7 support
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, ESD Guards, GPU Boost, ASUS EZ DIY, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Fan Xpert, ASUS TurboV, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Fanless Design Heatsink, AMD Radeon Dual Graphics, Conductive Polymer Capacitors, ASUS USB 3.0 Boost technology, AMD CrossFireX technology support, ASUS Network iControl, Disk Unlocker, AMD Turbo CORE 3.0 technology, 3+2 Phase Power Design
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS AI Suite II, ASUS AI Charger, ASUS Update
Plug and Play, ACPI 2.0a, ErP Ready
24.4 cm
23.4 cm
Limited warranty - 3 years
Scroll to top
