BT.com
Wishlist
Asus F2A55-M LK AMD FM2 A55 DDR3 mATX
Delivery
Standard Due date unavailable
F2A55-M LK: Digital power design for APUs with graphics performance boost
  • DIGI+ VRM - Digital Power Design for the APU
  • AI Suite II - One stop Access to Innovative ASUS Features
  • Network iControl - Real-time Network Bandwidth Control
  • UEFI BIOS - Flexible & Easy BIOS Interface
  • Windows 8 Ready - Assured Compatibility
AMD® A-series Accelerated Processor with AMD Radeon™ HD 7000 Series Graphics
This motherboard supports AMD® A-series Accelerated Processor with AMD Radeon™ HD 7000 Series Graphics. This revolutionary APU (Accelerated Processing Unit) combines processing power and advanced DirectX 11 graphics in one small, energy-efficient design to enable accelerated performance and an industry-leading visual experience. It features Dual-channel DDR3 memory support and accelerates data transfer rate up to 5GT/s.
AMD® A55 FCH (Hudson D2)
AMD® A55 FCH (Hudson D2) is designed to support up to 5GT/s interface speed and PCI Express™ 2.0 x 16(at x4 speed)graphics.
ASUS F2A55-M LK - motherboard - micro ATX - Socket FM2 - AMD A55
Motherboard - micro ATX
Chipset Type
AMD A55
Processor Socket
1 x Socket FM2
Compatible Processors
Athlon, A8 series, A6 series, A4 series, A10 series
Data Bus Transfer Rate
5 GT/s
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
6 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 2.0 + (6 x USB 2.0 via headers)
Max Allocated RAM Size
2048 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
AMD A55
5 GT/s
Processor Socket
Socket FM2
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, AMD Memory Profile (AMP)
Graphics
2048 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111F
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 1 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1 , 1 x PCI , 2 x DIMM 240-pin
Storage Interfaces
SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
1 x PS/2 keyboard , 1 x VGA , 1 x DVI , 1 x PS/2 mouse , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
6 x USB 2.0 , 1 x SPDIF out - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Features
ASUS Anti-Surge Protection, ESD Guards, GPU Boost, ASUS EZ DIY, CrashFree BIOS 3, ASUS EPU (Energy Processing Unit), ASUS Fan Xpert, ASUS TurboV, ASUS DIGI+ VRM, AMD Radeon Dual Graphics, ASUS Network iControl, 3+2 Phase Power Design
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS AI Suite II, ASUS Update
Plug and Play, RoHS, ACPI 2.0a, ErP Ready
24.4 cm
20.8 cm
Scroll to top
