Click to visit BT.com
BT.com
Wishlist
Asus F1A75-V PRO AMD A75 Hudson D3 FM1 DDR3 ATX
5.0*
Quicklinx: 7KNQWS00
Mfr#: F1A75-V PRO
Essential accessories
Asus F1A75-V PRO, AMD® A75 FCH (Hudson D3) Chipset, FM1 Socket Motherboard, ATX, Supports AMD® Fusion™A-& E2 series Accelerated Processor with AMD Radeon™ HD 6000 Series Graphics, up to 4 CPU cores.
The F1A75 series has been designed especially for optimized performance on the AMD Llano APUs, with exceptional overclocking capabilities for the versatile APU with a variety of integrated graphics built directly on the same die.
The ASUS F1A75 series have been designed with the exclusive DIGI+ VRM* and the most intuitive UEFI BIOS on the market. The F1A75-V EVO is also the world's first FM1 socket motherboard with dual x8/x8 PCI-Express for AMD CrossFireX™ support. Furthermore, the entire range of ASUS F1A75 Series motherboards are designed to natively support the latest USB 3.0 and SATA 6Gbps standards.
ASUS F1A75 Series motherboards are based on the latest AMD A75 chipset and FM1 socket, which supports AMD's new APUs. These include class leading performance from AMD Radeon™ HD 6000 series processor graphics with AMD Dual Graphics support. With an additional PCI-Express Radeon GPU to initiate Radeon Dual Graphics mode, the performance can be boosted up to 128%.**
The APU Radeon™ processor graphics offers DirectX® 11 technology, OpenGL Direct Compute and superb low power performance that is ideal for home media entertainment and gaming, without the need for an extra PCI-Express graphics card.
The premium F1A75 Series motherboards are equipped with DIP2, which features DIGI+ VRM technology in addition to the TPU and EPU. DIGI+ VRM power delivery allows a user to precisely adjust and control power settings digitally perfectly serving the APU specification's power demand. Digital control eliminates digital-to-analogue conversion lag, which helps to improve overclocking capabilities and enables precise power flow adjustment/management. Digital control also offers easy and flexible tuning, including extra DRAM power control for the AMD platform. System stability is also more efficient thanks to a smart thermal function, which includes phased temperature controls. For full system control, all features are accessible either by UEFI BIOS or AI Suite II. This all-in-one software offers diverse and easy-to-use functions, without the need to switch back and forth between different utilities while in Windows.
Included on all F1A75 Series motherboards is the previously mentioned UEFI BIOS menu interface. UEFI BIOS allows a user to control and adjust their BIOS settings through a mouse-enabled interface for more user-friendly navigation. The built-in EZ Mode option also provides a drag-and-drop boot priority option for easier management of boot devices, while the Advanced Mode allows experienced performance enthusiasts to tweak more intricate system settings. Overclockers can also save screen caps of their settings by pressing F12 on the keyboard and saving it onto a USB thumb drive.
ASUS DIGI+ VRM available on selected models) *(Test Configuration: MB: F1A75-V PRO/APU: AMD A8-3850 Memory: DDR3-1333 2048MB*2/ VGA:ASUS-EAH6670/DIS/1GD5/ OS: Win7 64bit)
ASUS Unique Selling Points
  • ASUS Dual Intelligent Processors 2 with DIGI+ VRM:
  • DIGI+VRM: Industry leading Digital 6+2 Phase Power Design
  • EPU Switch: Hardware level power saving.
  • TPU Switch with Auto Tuning and TurboV: Providing simple steps to easy overclocking.
  • UEFI BIOS(EZ Mode): Flexible & Easy BIOS Interface.
  • MemOK!: Quickly ensures memory boot compatibility.
  • Ai Charger+: Ensure reliable mobile phone charging.
  • AI Suite II: One-stop Access to All Innovative ASUS Software.
  • Anti-Surge Protection: Protect your hardware from over voltage.
  • EZ Flash 2: Easily update your systems bios firmware.
  • ASUS MyLogo 2: Customize your boot screen.
  • Precision Tweaker 2: Easily tune your PC system performance.
  • Fan Xpert: Smart thermal control via fan speed detection.
  • ASUS Q-Connector: Easily access your PCI-E connectors.
  • ASUS Q-Slot: Make Connection Quick and Accurate!
Key specification
  • Form Factor: Form Factor,12"x 9.6" (30.5cm x 24.4cm)
  • Socket: AMD Socket FM1 Supports AMD® Fusion™A-& E2 series Accelerated Processor with AMD Radeon™ HD 6000 Series Graphics,Up to 4 CPU cores.
  • Chipset: AMD® A75 FCH (Hudson D3)
  • Graphics interface: 2 x PCI Express 2.0 x16 slots (Single@x16 or dual@x16/x4 mode)
  • Expansion Slots: 2 x PCIe 2.0 x1 slots, 3 x PCI 2.2 slots.
  • Multi GPU: Supports and ATI® Quad-GPU CrossFireX™ Technology.
  • Memory: 4xDDR3 DIMM, max. 64GB,DDR3 1866 /1600 /1333/1066 MHz, non- ECC Unbuffered Memory with Dual Channel memory architecture.
  • Audio: ALC892 8-Chanhnel High Definition AUDIO CODEC
  • LAN: Realtek® 8111E Gigabit LAN controller
  • Storage: 6 x SATA 6Gb/s ports with RAID 0, 1, 10, 1x Serial ATA 6Gb/s connector(navy blue), 1x eSerial ATA 6Gb/s at the back I/O.
  • USB: 6 x USB3.0 ports (4 ports at back panel,2 ports at front panel), 10 xUSB2.0 ports(2 ports at back panel,8 ports at front panel)
Back Panel I/O Ports
  • 1 x PS/2 Keyboard/Mouse Combo port
  • 1 x DisplayPort
  • 1 x HDMI
  • 1 x DVI-D
  • 1 x D-Sub
  • 1 x Optical S/PDIF Output port
  • 1 x LAN (RJ45) port
  • 1 x eSATA port
  • 2 x USB 2.0 ports
  • 4 x USB 3.0 ports
  • 8 channel Audio 6 Jacks
Internal I/O Connectors
  • 1 x USB connectors support additional 2 USB 3.0 ports(19-pin)
  • 4x USB connectors support additional 8 USB 2.0 ports
  • 1 x S/PDIF Out connector
  • 1 x High Definition front panel audio connector
  • 7x SATA 6G connectors (6 x gray; 1 x navy blue)
  • 1 x COM connector
  • 1 x EPU switch
  • 1 x TPU switch
  • 1 x MemOK! Button
  • 1 x System Panel connector(20 pin)
  • 1 x CPU Fan connector(4-pin)
  • 2 x chassis Fan connector(4-pin)
  • 1 x Power Fan connector(3-pin)
  • 24-pin EATX power connector
  • 8-pin ATX 12V Power connector
In The Box
  • 2 x Serial ATA 6.0Gb/s cables
  • I/O Shield
  • 1 x Q-Shield
  • 1x Q-Connector
  • User's manual
  • Drivers
  • ASUS Utilities
  • ASUS Update
  • Anti-virus software (OEM version)
ASUS F1A75-V PRO - motherboard - ATX - Socket FM1 - AMD A75
Motherboard - ATX
Chipset Type
AMD A75
Processor Socket
1 x Socket FM1
Compatible Processors
A series, E2 series ( supports CPUs with up to 4 cores )
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x SATA-600, 1 x eSATA-600
USB / FireWire Ports
4 x USB 3.0 + 2 x USB 2.0 + ( 2 x USB 3.0 + 8 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Motherboard - ATX
Chipset Type
AMD A75
Processor Socket
Socket FM1
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Speed
PC3-12800, PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Controller
Realtek RTL8111E
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1 , 3 x PCI
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / JBOD , SATA-600 -connectors: 1 x 7pin Serial ATA - 1 devices , SATA-600 -connectors: 1 x 7pin external SATA - 1 devices
1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x VGA , 1 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 2 x USB 2.0 , 1 x TOSLINK , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Features
C.P.R. (CPU Parameter Recall), ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, ASUS EZ DIY, ASUS EPU (Energy Processing Unit), ASUS TurboV, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Dual Intelligent Processors 2, AMD CrossFireX technology support
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS Live Update, ASUS Auto Tuning, ASUS AI Suite II
Plug and Play, RoHS, ACPI 2.0a, ErP Ready
30.5 cm
24.4 cm
3 years warranty
Service & Support Details
Limited warranty - 3 years
Customer reviews
Write a review for the Asus F1A75-V PRO AMD A75 Hudson D3 FM1 DDR3 ATX here!
EXCELLENT
Reviewed by Stephen. Review Posted 27/11/2011
Just Built my new PC with this motherboard and the AMD A8, you won't be diapointed, its got a all the bells and whistles plus it looks good. Recommend this!!! The over clocking software is cool.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
