Click to visit BT.com
BT.com
Wishlist
Asus ATI Radeon 7850 870MHz 2GB PCI-Express 3.0 HDMI DirectCU II
5.0*
Quicklinx: 818ZWS00
Mfr#: HD7850-DC2-2GD5
HD7850-DC2-2GD5: Perfect balance of 28nm power with cool and quiet performance
  • DirectCU thermal utilizes direct-contact GPU heatpipes for 20% cooler and significantly quieter performance than reference.
  • GPU Tweak utility helps you modify and tune clock speeds, voltages, and fan performance via an intuitive interface.
  • AMD Eyefinity™ technology extends your viewing landscape across multiple monitors. ?
  • New PCIe 3.0 delivers double the bandwidth per lane of PCIe 2.0 for faster GPU-CPU communication
Deploy the Cool. Reign in Silence.
  • DirectCU II: 20% cooler with exclusive DirectCU II thermal solution
  • GPU Tweak: GPU Tweak co-developed with the most authoritative GPU-Z to provide the most accurate information
Graphics GPU Features
  • Powered by AMD Radeon™ HD 7850
  • 28nm GPU: Less power consumption & more efficient transistor
  • PCIE3.0: Delivers double the bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
  • AMD Eyefinity Technology: Extends your visual horizon across six displays for engaging gameplay and entertainment.
  • AMD HD3D™ Technology: Optimize stereoscopic 3D gaming and movie-watching entertainment.
  • DirectX® 11 Support: Bring new levels of visual realism to gaming on the PC and get top-notch performance
  • Software CrossFire X Support: Multi-GPU technology for extreme performance
  • Microsoft® Windows® 7 Support: Enable PC users to enjoy an advanced computing experience and to do more with their PC
ASUS HD7850-DC2-2GD5 graphics card - Radeon HD 7850 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7850
2 GB - GDDR5
Core Clock
870 MHz
Effective Memory Clock
4.84 GHz
RAMDAC
400 MHz
Memory Interface
256-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
DVI-I (dual link) , HDMI , 2 x Mini DisplayPort
API Supported
DirectX 11
4.3 cm x 25.9 cm x 11.4 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7850
Core Clock
870 MHz
RAMDAC
400 MHz
Process Technology
28 nm
Max Resolution
2560 x 1600
API Supported
DirectX 11
AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, ASUS DirectCU II Technology , HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
4.84 GHz
Bus Width
256-bit
Software Included
Drivers & Utilities, ASUS GPU Tweak
4.3 cm
25.9 cm
11.4 cm
Customer reviews
Write a review for the Asus ATI Radeon 7850 870MHz 2GB PCI-Express 3.0 HDMI DirectCU II here!
Great Card
Reviewed by Flo. Review Posted 02/10/2012
First one I got was faulty, was instantly replaced, and haven't had any trouble with it since. runs most games at 120 fps, excluding of course battlefield with which can get up to ~55 frames at high settings.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
