Asus AMD Ultimate Bundle (Includes CROSSHAIR V FORMULA-Z, AMD FX-8320 & 8GB Vengeance LP Memory)
Standard Due date unavailable
Exclusive Self-Build Special Bundle
High Performance - Without The High Price Tag!
Take the fear out of Self-Build with this tested AMD Ultimate Bundle! We test it so you don't have to! Motherboard, CPU and Memory - Boxed & Ready To Rock
Asus Crosshair V Formula-Z AMD Motherboard: Upgraded 990FX motherboard with exclusive ROG gaming audio and networking technologies
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in.
In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers.
This motherboard supports latest AMD® Socket AM3+ multi-core processors with up to 8 native CPU cores and delivers better overclocking capabilities with less power consumption. It features AMD® Turbo CORE Technology 2.0 and accelerates data transfer rate up to 5200MT/s via HyperTransport™ 3.0 based system bus. This motherboard also supports AMD® CPUs in the new 32nm manufacturing process.
AMD® 990FX Chipset is designed to support up to 5.2GT/s HyperTransport™ 3.0 (HT 3.0) interface speed and dual PCI Express™ 2.0 x16 graphics. It is optimized with AMD® latest AM3+ and multi-core CPUs to provide excellent system performance and overclocking capabilities.
This motherboard supports DDR3 2400(O.C.) that provides faster data transfer rate and more bandwith to increase memory computing efficiency, enhancing system performance in 3D graphics and other memory demanding applications.
SLI™ or CrossFireX™? Fret no longer because with the Crosshair V Formula-Z you'll be able to run both multi-GPU setups. The board features SLI™/CrossFire™ on Demand technology, supporting up to four graphics cards in a Quad-GPU SLI or 3-Way SLI™ / CrossFireX™ configuration. Whichever path you take, you can be assured of jaw-dropping graphics at a level previously unseen.
The SupremeFX III™ onboard audio solution is an 8-channel HD audio equipped with a carefully selected 1500uF capacitor which provides clean, ripple-free audio power and - perfect for enveloping gaming environments. With a metallic EMI cover and special layout design on the PCB, advanced SupremeFX Shielding™ technology isolates analog audio signals from digital sources for exceptional clarity and high fidelity, while a gold-plated jack ensures rich notes reach your ears with minimal distortion.
  • Extreme Engine Digi+ II -- Powerful combination of analog and digital design elements
  • SupremeFX III -- Play with ultra-real cinematic in-game surround sound!
  • GameFirst II-- Put your frags first - 3-Way NIVDIA® SLI™ / AMD CrossFireX™ Technology - Intel® Gigabit LAN -- Experience the fast network connectivity! - UEFI BIOS -- Flexible & Easy BIOS Interface
  • Supercharged Audio and Ultrafast LAN
  • Windows 8 Ready - Assured Compatibility
AMD FX8-8320 Black Edition Vishera 8 Core AM3+ 3.5GHz 16MB 125W Processor (FD8320FRHKBOX)
The new AMD FX 8320 Black Edition Processor with 8 cores, and it's unlocked for your overclocking pleasure. Experience unmatched multitasking and pure core performance with the 32nm 8-core desktop processor. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed with easy-to-use AMD OverDrive™ and AMD Catalyst Control Center™ software suites. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
  • Unlocked AMD FX 8-Core Processor
  • AMD Turbo CORE Technology
  • New Instruction Capabilities
  • AMD Balanced Smart Cache
  • AMD Wide Floating Point Accelerator
  • HyperTransport™ Technology
  • Integrated DRAM Controller with AMD Memory Optimizer Technology
  • AMD Virtualization™ (AMD-V™) Technology
  • AMD PowerNow!™ Technology (Cool'n'Quiet™ Technology)
AMD's product warranty does not cover damage caused by overclocking even when overclocking is enabled via AMD OverDrive™ software.
Corsair 8GB (2x4GB) DDR3 1600Mhz CL9 Vengeance Low Profile Blue Performance Desktop Memory Kit (CML8GX3M2A1600C9B)
Corsair Vengeance DDR3 memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
ASUS Crosshair V Formula-Z Republic of Gamers - motherboard - ATX - Socket AM3+ - AMD 990FX
Motherboard - ATX
Chipset Type
AMD 990FX / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Athlon X2, Sempron X2, Phenom II X4, Phenom II X6, FX ( supports CPUs with up to 8 cores, Maximum TDP 140 Watt )
Data Bus Transfer Rate
5.2 GT/s
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC, ECC , unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x SATA-600, 2 x eSATA-600
USB / FireWire Ports
4 x USB 3.0 + 8 x USB 2.0 + ( 2 x USB 3.0 + 4 x USB 2.0 via headers )
HD Audio (8-channel)
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Max Bus Speed
2600 MHz
5.2 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
Supported RAM
Max Size
32 GB
Bus Clock
2400 MHz, 2000 MHz, 1800 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 2133 MHz
Supported RAM Integrity Check
Registered or Buffered
Dual channel memory architecture
Audio Codec
SupremeFX III
DTS Connect, High Definition Audio, DTS UltraPC II
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 3 x PCIe 2.0 x16 ( CrossFireX: dual x16 mode; triple: x16, x8, x8 mode; SLI: dual x16 mode; triple: x16, x8, x8 mode ) , 1 x PCIe 2.0 x16 ( x4 mode ) , 2 x PCIe 2.0 x1
Storage Interfaces
AMD SB950: SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin SATA, 2 x 7pin eSATA - 4 devices
1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 8 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
2 x USB 3.0 - header , 4 x USB 2.0 - header , 1 x SPDIF out - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ASUS MyLogo3, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support, UEFI BIOS
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall), AMD Cool 'n' Quiet Technology, jack retasking, ASUS Q-Design, GameFirst, ROG Connect, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, ProbeIt, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS COP EX, ASUS Q-Shield, NVIDIA 3-way SLI Technology Support, ASUS 8+2 Phase Power Design, ASUS Fan Xpert, NVIDIA Quad SLI Technology Support, ASUS iROG, ASUS TurboV, Core Unlocker, GPU.DIMM Post, ROG BIOS Print, ROG CPU-Z, USB 3.0 Boost, ASUS Extreme Engine Digi+ II, Q-Code, SupremeFX Shielding technology, AMD 3-way CrossFireX technology support, ASUS 2 Phase DRAM Power Design, Disk Unlocker
6 x Serial ATA cable , 1 x 3-way SLI bridge , 1 x SLI bridge , 1 x CrossFire cable
Software Included
Drivers & Utilities, ASUS TurboV EVO Utility, Kaspersky Anti-Virus, ASUS AI Suite II, ROG CPU-Z, ROG GameFirst Utility, DAEMON Tools Pro Standard, ASUS WebStorage, ASUS Update
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
Scroll to top
