BT.com
Wishlist
Asus AMD Radeon Fury X Graphics 4GB HBM PCIe3.0 Graphics Card
Delivery
Standard Due date unavailable
Like nothing you’ve seen before
The AMD Radeon™ R9 Fury X graphics card is the world’s first total solution GPU with AMD-pioneered High-Bandwidth Memory (HBM) on-chip delivering extreme 4K performance and unbelievably "real" VR experiences.
Don’t just upgrade. Revolutionize with the AMD Radeon™ R9 Fury X graphics card.
AMD High Bandwidth Memory
- High-Bandwidth Memory with more than 3x the bandwidth per watt over GDDR5 along with a 4096-bit memory interface - the highest AMD GPU memory bandwidth ever.
- Sleek industrial styling including GPU Tach activity indicator and LED illumination all in a compact 7.5-inch card that’s all about raw graphics power.
- Powerful performance, bleeding-edge technology, liquid-cooled, whisper-quiet and future-ready for extreme 4K and VR gaming.
Redefine reality with AMD LiquidVR™ technology.
- Liquid-smooth images with high frame rates for a definitive VR experience.
- Get comfortable with low-latency head tracking.
- Designed for plug-and-play headset compatibility.
Enjoy the View in 4K.
- Command the competition at 4K resolution and beyond, fueled by a 4096-bit high-bandwidth memory interface for extreme performance and power efficiency.
- Take advantage of full support for DirectX® 12, Vulkan™, OpenGL® 4.5 and Mantle.
- Experience the smoothest gameplay without frame-tearing or stuttering with an AMD Eyefinity 3x1, using 1440p FreeSync™-enabled monitors for a massive 6K gameplay "surround view" panorama.
Specs
Graphics Engine - AMD Radeon™ R9 FURY X
Bus Standard - PCI Express 3.0
OpenGL 4.4
Video Memory - 4GB HBM
Engine Clock - 1050MHz
Stream Processors - 4096
Memory Clock - 500 MHz
Memory Interface - 4096bit
Digital Max. Resolution - 4096 x 2160
DVI Output - No
HDMI Output - 1 x Native HDMI
HDCP Compliant - Yes
Display Port - 3 x Native Display Port
ASUS R9FURYX-4G graphics card - Radeon R9 Fury X - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 Fury X
4 GB HBM
Core Clock
1050 MHz
Effective Memory Clock
500 MHz
Memory Interface
4096-bit
Max Resolution
4096 x 2160
HDMI , 3 x DisplayPort
API Supported
OpenGL 4.4, DirectX 12
3.9 cm x 19.5 cm x 11.5 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1050 MHz
Max Resolution
4096 x 2160
API Supported
Native HDMI, AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, Super Alloy Power technology, ASUS DIGI+ VRM, HDCP
Size
4 GB
HBM
Effective Clock Speed
500 MHz
Bus Width
4096-bit
Software Included
Display drivers, XSplit Gamecaster (1 year Premium licence), ASUS GPU Tweak II
3.9 cm
19.5 cm
11.5 cm
Scroll to top
