Click to visit BT.com
BT.com
Wishlist
Asus AMD Radeon 7990 HD 1GHz 6GB PCI-Express 3.0 HDMI
Quicklinx: 8PRFWS00
Mfr#: HD7990-6GD5
ASUS HD 7990: dual-GPU power for an ultra-gaming future
  • 6GB GDDR5 memory for the best gaming experiences in the highest resolutions
  • DirectX® 11.1 brings new levels of visual realism to PC gaming with top-notch performance
  • GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface
Graphics GPU Features
  • Powered by AMD Radeon™ HD 7990
  • AMD Eyefinity™ Technology: Extend the view across up to 6 displays to immerse yourself in gameplay and entertainment.
  • CrossFire X Support: Multi-GPU technology for extreme performance.
  • AMD HD3D™ Technology: Optimize stereoscopic 3D gaming and movie-watching entertainment.
  • PCI Express 3.0: Delivers double the bandwidth per lane of PCIe 2.0 for faster GPU-CPU communication.
  • Microsoft DirectX® 11.1 API (feature level 11_0): Brings new levels of visual realism to gaming on the PC and get top-notch performance.
  • Microsoft Windows 8 compatible: Gives you access to advanced computing experiences with the latest operating system so you get more done with your PC.
  • Graphics Engine: AMD Radeon HD 7990
  • Bus Standard: PCI Express 3.0
  • Video Memory: GDDR5 6GB
  • Engine Clock: 1000 MHz
  • Memory Clock: 6000 MHz ( 1500 MHz GDDR5 )
  • Memory Interface: 384-bit x2
  • Resolution: DVI Max Resolution : 2560x1600
  • DVI Output : Yes x 1 (DVI-I)
  • Display Port : Yes x 4 (Mini DP)
  • HDCP Support : Yes
  • 1 x CrossFire cable
  • 1 x DVI to HDMI adaptor
  • 1 x Mini DP to DVI adaptor
  • Power Consumption: up to 375Wadditional 8+8 pin PCIe power required
  • Software: ASUS GPU Tweak & Driver
  • Fan Sink
  • Dimensions: 12 " x 4.375 " x 1.45 " Inch / 30.48 x 11.11 x3.7 Centimeter
ASUS HD7990-6GD5 graphics card - 2 GPUs - Radeon HD 7990 - 6 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GPUs - AMD Radeon HD 7990
6 GB GDDR5
Core Clock
1000 MHz
Effective Memory Clock
6 GHz
Memory Interface
2 x 384-bit
Max Resolution
2560 x 1600
Max Monitors Supported
6
DVI-I (dual link) , 4 x Mini DisplayPort , HDMI - with adapter
API Supported
DirectX 11.1
3.7 cm x 30.48 cm x 11.11 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1000 MHz
Max Resolution
2560 x 1600
6
API Supported
DirectX 11.1
AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology , HDCP
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
6 GHz
Bus Width
2 x 384-bit
Additional Requirements
2 x 8 pin PCI Express power connector
375 Watt
1 x CrossFire cable , 1 x HDMI-DVI adapter , 1 x Mini DisplayPort-DVI adapter
Software Included
Drivers & Utilities, ASUS GPU Tweak
3.7 cm
30.48 cm
11.11 cm
