Click to visit BT.com
BT.com
Wishlist
Asus AMD Radeon 7770 HD 1GHz 1GB PCI-Express 3.0 HDMI
Quicklinx: 864DWS00
Mfr#: HD7770-1GD5
ASUS HD7770-1GD5 Feel the Power of the 28nm GPU with fantastic ASUS design!!
ASUS, today introduces the ASUS HD7770-1GD5 to users around the world. It is equipped with DIGI+ VRM and Super Alloy Power which reaches 15% performance increase, 2.5 times longer product lifespan and 350C cooler operation for precise digital delivery and enhanced durability. Besides, ASUS HD7770-1GD5 also comes with exclusive GPU Tweak utility, which allows users to modify clock speeds, voltages, and fan performance.
  • Acclaimed DIGI+ VRM with Super Alloy Power technology delivers precise digital power and enhanced durability for stable overclocking. - Dust-proof Fan design increases particle resistance and extends card lifespan by up to 25% longer than reference. - GPU Tweak utility allows you to tune graphics card performance and check card status via an intuitive interface
Product Spec
  • Graphics Engine AMD Radeon™ HD 7770
  • Bus Standard PCI Express® 3.0
  • OpenGL OpenGL® 4.2
  • Video Memory 1GB GDDR5
  • Engine Clock 1000 MHz
  • Stream Processor 640
  • Memory Clock 4500MHz (1125MHz GDDR5)
  • Memory Interface 128 bit
  • RAMDAC 400MHz
  • DVI Max. Resolution 2560* 1600
  • D-Sub Max. Resolution 2048* 1536
  • D-SubOutput YES X1 (through DVI to D-Sub adaptor)
  • DVI Output YES X1(Native)
  • HDMI Output YES X1 (Native)
  • DisplayPort YES X1(Native)
  • HDCP compliant YES
  • Adapter/Cable Bundled 1x DVI to D-subadaptor
  • 1x CROSSFIRE BRIDGE CABLE
ASUS HD7770-1GD5 graphics card - Radeon HD 7770 - 1 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7770
1 GB GDDR5
Core Clock
1000 MHz
Stream Processors
640
Effective Memory Clock
4.5 GHz
RAMDAC
400 MHz
Memory Interface
128-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
3
DVI-I (dual link) , DisplayPort , HDMI , VGA - with adapter
API Supported
DirectX 11, OpenGL 4.2
3.8 cm x 19.1 cm x 13.5 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7770
Core Clock
1000 MHz
Stream Processors
640
RAMDAC
400 MHz
Process Technology
28 nm
Max Resolution
2560 x 1600
3
API Supported
Native HDMI, AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, Super Alloy Power technology, Dust-proof fan, ASUS DIGI+ VRM , HDCP
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
4.5 GHz
Bus Width
128-bit
1 x DVI-VGA adapter , 1 x CrossFire internal bridge
Software Included
Drivers & Utilities, ASUS GPU Tweak
3.8 cm
19.1 cm
13.5 cm
Resources
The following resources are available for the Asus AMD Radeon 7770 HD 1GHz 1GB PCI-Express 3.0 HDMI
