BT.com
Wishlist
Asus AMD Performance Bundle (Includes M4A78LT-M Motherboard, AMD Phenom II X2 560 BE & 2GB DDR3 Memory)
Delivery
Standard Due date unavailable
Exclusive Self-Build Special Bundle
Perfect Performance PC!
Take the fear out of Self-Build with this tested AMD Performance Bundle! We test it so you don't have to! Motherboard, CPU and Memory - Boxed & Ready To Rock!
Asus M4A78LT-M AMD Motherboard
This motherboard supports AMD AM3 multi-core processors with unique L3 cache and delivers better overclocking capabilities with less power consumption. It features dual-channel DDR3 memory support and accelerates data transfer rate up to 5200MT/s via HyperTransport 3.0 based system bus. This motherboard also supports AMD CPUs in the 45nm manufacturing process.
The motherboard supports DDR3 memory that features data transfer rates of 1800+(O.C.)/1600(O.C.)/1333/1066 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 25.6Gbps. Furthermore, the supply voltage for the memory is reduced from 1.8 V for DDR2 to just 1.5 V for DDR3. This voltage reduction limits the power consumption and heat generation of DDR3 which makes it an ideal memory solution
AMD Phenom II X2 560 3.3GHz Black Edition Processor (HDZ560WFGMBOX)
AMD Phenom II X2 Black Edition processor combines value and unlocked potential for gamers and tuners on a budget. Users can now experience the power of AMD platform technology, codenamed "Dragon" with dual-core configurations. AMD Black Edition processors help users to take control and unleash the maximum potential of Dragon platform technology's unprecedented performance tuning capabilities. With dual-core processors, AMD provides platform level solutions at multiple price points, each of which exceeds expectations for virtually any user.
Patriot Signature 2GB DDR3 CL9 PC3-10600 1333MHz Memory (PSD32G13332H)
Designed with reliability, performance and value in mind, Patriot Signature DDR3 PC3-10600 (1333MHz) is the perfect memory upgrade solution for desktop and workstation systems. Patriot ensures that every memory module meets and exceeds industry standards.
ASUS M4A78LT-M - motherboard - micro ATX - Socket AM3 - AMD 760G
Motherboard - micro ATX
Chipset Type
AMD 760G / AMD SB710
Processor Socket
1 x Socket AM3
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4
Max RAM Size
16 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC, ECC , unbuffered
Storage Ports
1 x ATA, 6 x SATA
USB Ports Configuration
12 x USB
Graphics
ATI Radeon 3000
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Max Bus Speed
2600 MHz
Processor Socket
Socket AM3
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1333 MHz, 1066 MHz
Speed
PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
Graphics Controller
ATI Radeon 3000
Memory Allocation Technology
Shared Video Memory (UMA)
1 GB
Audio
Audio Codec
VIA VT1708S
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin ( 1.5 V ) , 1 x PCIe 2.0 x16 , 1 x PCIe x1 , 2 x PCI
Storage Interfaces
AMD SB710: SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / JBOD , AMD SB710: ATA-133 -connectors: 1 x 40pin IDC - 1 devices
1 x DVI-D , 1 x VGA , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet) , 6 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-out (rear)/line-in - mini-jack , 1 x audio line-out (centre/subwoofer)/microphone - mini-jack , 1 x HDMI , 1 x TOSLINK
Additional Connectors (Optional)
6 x USB 2.0
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support
Manual Settings
CPU frequency, memory voltage
Hardware Features
ASUS Q-Fan, C.P.R. (CPU Parameter Recall), AMD Cool 'n' Quiet Technology, jack retasking, ASUS Anti-Surge Protection, ASUS Turbo Key, CrashFree BIOS 3, ASUS AI NET2, ASUS Stepless Frequency Selection (SFS), audio jack detect technology, HDCP compliant, ASUS Express Gate, ASUS EPU-4 Engine, AMD Hybrid CrossFireX technology support
2 x Serial ATA cable , 1 x IDE cable
Software Included
Drivers & Utilities, ASUS Live Update, ASUS PC Probe 2, ASUS AI Suite
Plug and Play, RoHS, ACPI 2.0a
24.4 cm
24.4 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Outstanding Piece of Kit :)
Reviewed by on 22/10/2010
Very easy to install, and amazingly fast. i upgraded form a pentium 4 runnin very slow ddr2 ram. this is a great bundle still amazed by the performance difference. would diffently recommend to anyone
5* my 2010 upgrade
Reviewed by ramduck on 04/11/2010
lost a point on easy to use because they dont tell you the cpu comes with a cooling fan.heads up only one ide connector on motherboard so get them sata drives ready.but otherwise great bundle.great price.ordered thursday night was on my doorstep monday morning.and been using BT for almost ten years now and always been looked after. for pc bits i dont go anywhere eles
5* Like it says on the can...Performance
Reviewed by axia on 16/12/2010
What can I say?
Easy to install.
Superb speed.
Delivery took a long time but that was due to the weather.
This is defo the route to go to upgrade your old P4.
Very satisfied
5* Excellent value bundle
Reviewed by on 30/01/2011
The Phenom X2 black edition is known for being unlockable, effectively giving you an X3 or X4 cpu. The Asus board allows very straight forward unlocking. I've had success with this bundle, unlocking the two extra cores. Load tested at 100% for twenty four hours with no issues at all. Excellent value for money!
Scroll to top
