Asus AMD Performance Bundle (Includes F2A55-M LK, AMD A8-5600K & 8GB Corsair Vengeance LP Memory)
Standard Due date unavailable
Exclusive Self-Build Special Bundle
For Those Looking For A Little Bit More On a Budget - Power & Performance at a Fantastic Price!
Take the fear out of Self-Build with this tested AMD Performance Bundle! We test it so you don't have to! Motherboard, CPU and Memory - Boxed & Ready To Rock!
Asus F2A55-M LK AMD Motherboard
This motherboard supports AMD® A-series Accelerated Processor with AMD Radeon™ HD 7000 Series Graphics. This revolutionary APU (Accelerated Processing Unit) combines processing power and advanced DirectX 11 graphics in one small, energy-efficient design to enable accelerated performance and an industry-leading visual experience. It features Dual-channel DDR3 memory support and accelerates data transfer rate up to 5GT/s.
AMD® A55 FCH (Hudson D2) is designed to support up to 5GT/s interface speed and PCI Express™ 2.0 x 16(at x4 speed)graphics.
ASUS motherboards using the AMD® A55 chipset employ precise digital voltage regulation for the APU, called DIGI+ VRM (Voltage Regulation Modules) digital power design. The APU voltage is adjusted via either carefully developed automated modes, or by using user-defined profiles. The effect is that DIGI+ VRM technology ensures greater energy efficiency and the most precise power delivery. Boosted by world-renowned ASUS quality, it creates an ideal computing platform for a diverse range of applications, from gaming to multimedia or office work and heavy multitasking. Engineered and tested to assure unmitigated performance, ASUS A55 boards with DIGI+ VRM remain efficient and accurate, for reliable application in every scenario.
AMD A8-5600K 3.6GHz FM2 4MB 100W Black Edition (AD560KWOHJBOX)
One processor. Endless possibilities.
Experience your digital life with virtually no limits through the accelerated performance of the 2nd generation AMD A-Series Processor. Get the performance of multicore CPU technology and the brilliance of premium AMD Radeon™ graphics technology -- all in a single chip, at a great price! A8 -- Quad-core accelerated processor
  • Transform your photos up to 3x faster than the Intel Core i3
  • Work smarter and game harder with multi-display support from AMD Eyefinity technology.
  • Unlock all the control and performance of the 2nd generation AMD A-Series Processor when you select the overclockable Black Edition.
Corsair 8GB (2x4GB) DDR3 1600Mhz CL9 Vengeance Low Profile Blue Performance Desktop Memory Kit (CML8GX3M2A1600C9B)
Corsair Vengeance DDR3 memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
ASUS F2A55-M LK - motherboard - micro ATX - Socket FM2 - AMD A55
Motherboard - micro ATX
Chipset Type
Processor Socket
1 x Socket FM2
Compatible Processors
Athlon, A8 series, A6 series, A4 series, A10 series
Data Bus Transfer Rate
5 GT/s
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
6 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 2.0 + ( 6 x USB 2.0 via headers )
Max Allocated RAM Size
2048 MB
HD Audio (8-channel)
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
5 GT/s
Processor Socket
Socket FM2
Max Processors Qty
Supported RAM
Max Size
32 GB
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Supported RAM Integrity Check
Registered or Buffered
Dual channel memory architecture, AMD Memory Profile (AMP)
2048 MB
Audio Codec
Realtek ALC887
High Definition Audio
Network Controller
Realtek RTL8111F
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 1 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1 , 1 x PCI , 2 x DIMM 240-pin
Storage Interfaces
SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
1 x PS/2 keyboard , 1 x VGA , 1 x DVI , 1 x PS/2 mouse , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
6 x USB 2.0 , 1 x SPDIF out - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Features
ASUS Anti-Surge Protection, ESD Guards, GPU Boost, ASUS EZ DIY, CrashFree BIOS 3, ASUS EPU (Energy Processing Unit), ASUS Fan Xpert, ASUS TurboV, ASUS DIGI+ VRM, AMD Radeon Dual Graphics, ASUS Network iControl, 3+2 Phase Power Design
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS AI Suite II, ASUS Update
Plug and Play, RoHS, ACPI 2.0a, ErP Ready
24.4 cm
20.8 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Unexpected problems
Reviewed by Mike Day on 16/02/2013
The instruction manual is very detailed and it proved unexpectedly easy to fit as a replacement, higher performance motherboard. The BT recommended thermal paste I bought was not needed. The processor heat sink is already coated ready for fitting. My main problems have been with the software. I could not start Windows7 to install the drivers. Eventual solution -change the default setting for SATA drives from AHCI to IDE. Then it would not recognise my widescreen monitor and allow me to set it to 1920x1080. Solution - install the graphics driver a second time. Then my old PS2 mouse was not recognised. Solution - go out any buy a new USB one. Not yet found how to stop the case fan running continuously but everything else now working properly. Windows index for processor, memory and gaming graphics speeds are much improved, but desktop graphics performance with Aero is a bit disappointing.
3* I got this cheap
Reviewed by Nec_V20 on 03/04/2013
I got a return version of this deal and when I received it I immediately knew why. With regard to the way that the cooling paste residues were distributed on the processor and the stock cooling fan the person building it was an idiot. There was hardly any paste on the centre of the processor but an abundance at the edges - especially the top left hand corner. For God's sakes folks there are YouTube videos showing you how to put the paste on the CPU properly! Anyway, I have had the combo running for a burn in period of 24 hours with prime98 running and even though I am running it on the stock cooler (I am waiting for my H60 to arrive, because this is my secondary media server which I'll upgrade/good enough to do what I want if my Core i7 990x goes down for any reason so I want something to go forever - that being a relative term) it is still well within the TDP specification of the CPU. OK so I have it in a CoolerMaster HAF XM casing, which for some reason BT doesn't offer.
Scroll to top
