BT.com
Wishlist
Asus AMD Performance Bundle (Includes F2A55-M LK, AMD A8-5600K & 4GB XMS Memory)
Delivery
Standard Due date unavailable
Exclusive Self-Build Special Bundle
For Those Looking For A Little Bit More On a Budget - Power & Performance at a Fantastic Price!
Take the fear out of Self-Build with this tested AMD Performance Bundle! We test it so you don't have to! Motherboard, CPU and Memory - Boxed & Ready To Rock!
Asus F2A55-M LK AMD Motherboard
This motherboard supports AMD® A-series Accelerated Processor with AMD Radeon™ HD 7000 Series Graphics. This revolutionary APU (Accelerated Processing Unit) combines processing power and advanced DirectX 11 graphics in one small, energy-efficient design to enable accelerated performance and an industry-leading visual experience. It features Dual-channel DDR3 memory support and accelerates data transfer rate up to 5GT/s.
AMD® A55 FCH (Hudson D2) is designed to support up to 5GT/s interface speed and PCI Express™ 2.0 x 16(at x4 speed)graphics.
ASUS motherboards using the AMD® A55 chipset employ precise digital voltage regulation for the APU, called DIGI+ VRM (Voltage Regulation Modules) digital power design. The APU voltage is adjusted via either carefully developed automated modes, or by using user-defined profiles. The effect is that DIGI+ VRM technology ensures greater energy efficiency and the most precise power delivery. Boosted by world-renowned ASUS quality, it creates an ideal computing platform for a diverse range of applications, from gaming to multimedia or office work and heavy multitasking. Engineered and tested to assure unmitigated performance, ASUS A55 boards with DIGI+ VRM remain efficient and accurate, for reliable application in every scenario.
AMD A8-5600K 3.6GHz FM2 4MB 100W Black Edition (AD560KWOHJBOX)
One processor. Endless possibilities.
Experience your digital life with virtually no limits through the accelerated performance of the 2nd generation AMD A-Series Processor. Get the performance of multicore CPU technology and the brilliance of premium AMD Radeon™ graphics technology -- all in a single chip, at a great price! A8 -- Quad-core accelerated processor
  • Transform your photos up to 3x faster than the Intel Core i3
  • Work smarter and game harder with multi-display support from AMD Eyefinity technology.
  • Unlock all the control and performance of the 2nd generation AMD A-Series Processor when you select the overclockable Black Edition.
Corsair 4GB DDR3 1600Mhz XMS3 Performance Desktop Memory Module
he XMS3 family is Corsair's mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair's new XMS heat spreaders, each module is built using carefully selected RAMs.
ASUS F2A55-M LK - motherboard - micro ATX - Socket FM2 - AMD A55
Motherboard - micro ATX
Chipset Type
AMD A55
Processor Socket
1 x Socket FM2
Compatible Processors
Athlon, A8 series, A6 series, A4 series, A10 series
Data Bus Transfer Rate
5 GT/s
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
6 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 2.0 + ( 6 x USB 2.0 via headers )
Max Allocated RAM Size
2048 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
AMD A55
5 GT/s
Processor Socket
Socket FM2
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, AMD Memory Profile (AMP)
Graphics
2048 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111F
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 1 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1 , 1 x PCI , 2 x DIMM 240-pin
Storage Interfaces
SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
1 x PS/2 keyboard , 1 x VGA , 1 x DVI , 1 x PS/2 mouse , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
6 x USB 2.0 , 1 x SPDIF out - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Features
ASUS Anti-Surge Protection, ESD Guards, GPU Boost, ASUS EZ DIY, CrashFree BIOS 3, ASUS EPU (Energy Processing Unit), ASUS Fan Xpert, ASUS TurboV, ASUS DIGI+ VRM, AMD Radeon Dual Graphics, ASUS Network iControl, 3+2 Phase Power Design
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS AI Suite II, ASUS Update
Plug and Play, RoHS, ACPI 2.0a, ErP Ready
24.4 cm
20.8 cm
Scroll to top
