Click to visit BT.com
BT.com
Wishlist
Asus AMD Gamer Bundle (Includes M5A97 R2.0, AMD FX-4170 & 8GB Corsair Vengeance LP Memory)
5.0*
Quicklinx: 8H7TWS00
Mfr#: ASUSAMD-FXGAMER4
Essential accessories
Exclusive Self-Build Special Bundle
High Performance - Without The High Price Tag!
Take the fear out of Self-Build with this tested AMD Gamer Bundle! We test it so you don't have to! Motherboard, CPU and Memory - Boxed & Ready To Rock
Asus M5A97 R2.0 AMD Motherboard
ASUS continues to put innovation at its forefront, launching the world's first Dual Intelligent Processors technology. This exclusive design consists of the EPU (Energy Processing Unit), which automatically monitors power consumption system-wide to ensure efficiency, and the TPU (TurboV Processing Unit) - guaranteeing superior performance for every task, bringing users an unbeatable experience.
M5A97 R2.0 supports AMD® AM3+/AM3 multi-core processors with unique L3 cache and delivers better overclocking capabilities with less power consumption. It features dual-channel DDR3 1866 memory support and accelerates data transfer rate up to 5200MT/s via HyperTransport™ 3.0 based system bus. This motherboard also supports AMD® CPUs in the new 32nm manufacturing process.
AMD® 970 Chipset is designed to support up to 4800MT HyperTransport™ 3.0 (HT 3.0) interface speed and PCI Express™ 2.0 x16 graphics. It is optimized with AMD®'s latest AM3+ and multi-core CPUs to provide excellent system performance and overclocking capabilities.
AMD FX-4170 AM3+ 4.2GHz 12MB 125W Processor (FD4170FRGUBOX)
Blow away the competition with the unrestrained powered of an AMD FX processor. Unlocked out of the box and competitively priced, AMD FX processors give you more bang for your buck with aggressive performance and lightning fast responsiveness.
  • Socket - AM3+
  • Clock Speed - 4.2GHz
  • Turbo Clock Speed - 4.3GHz
  • System bus - 5.2 GT/s
  • Multiplier Unlocked
  • L2 Cache - 4MB
  • L3 Cache - 8MB
  • TDP - 125W
  • Voltage - 0.925v - 1.4125v
  • Technology - 32nm
  • HyperTransport 3.0 Technology
**Corsair 8GB (2x4GB) DDR3 1600Mhz CL9 Vengeance Low Profile Blue
Performance Desktop Memory Kit (CML8GX3M2A1600C9B)**
Corsair Vengeance DDR3 memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
ASUS M5A97 - 2.0 - motherboard - ATX - Socket AM3+ - AMD 970
Motherboard - ATX
Chipset Type
AMD 970 / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Athlon X2, Sempron X2, Phenom II X4, Phenom II X6, FX ( supports CPUs with up to 8 cores, Maximum TDP 140 Watt )
Data Bus Transfer Rate
4.8 GT/s
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 6 x USB 2.0 + ( 2 x USB 3.0 + 6 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3 years warranty
Motherboard - ATX
Chipset Type
AMD 970 / AMD SB950
4.8 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111F
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x16 ( x4 mode ) , 2 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
AMD SB950 : SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 6 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
6 x USB 2.0 , 1 x serial - header , 1 x SPDIF out - header , 1 x audio - header , 2 x USB 3.0
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, USB BIOS Flashback, ASUS EFI BIOS, UEFI BIOS, SMBIOS 2.7 support
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall), AMD Cool 'n' Quiet Technology, jack retasking, MemOK!, ASUS Q-Design, ASUS 4+2 Phase Power Design, ASUS EZ DIY, Q-Slot, ASUS Noise Filter, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Precision Tweaker 2, ASUS Fan Xpert, ASUS TurboV, Fanless Design Heatsink, USB 3.0 Boost, AMD Quad CrossFireX technology support, ASUS Network iControl, ASUS Remote GO!, DirectKey
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Suite II, ASUS AI Charger+
Plug and Play, RoHS, ACPI 2.0a, ErP Ready
30.5 cm
22.9 cm
3 years warranty
Service & Support Details
Limited warranty - 3 years
Customer reviews
Write a review for the Asus AMD Gamer Bundle (Includes M5A97 R2.0, AMD FX-4170 & 8GB Corsair Vengeance LP Memory) here!
Exellent budget gaming bundle!
Reviewed by Roger3636. Review Posted 28/05/2013
Great little bundle! up and running in 20 minutes fired up first time. Also bought a HD7870 to go with it, runs all my games on ultra settings in 1080p with no stuttering!!
Very very pleased!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
