BT.com
Wishlist
Asus A88X-PLUS/USB 3.1 AMD FM2+ A88X DDR3 ATX Motherboard
Delivery
Standard 3-5 working days
Great-value micro-ATX A88X with 5X Protection II for dependable stability, LED-illuminated audio shielding and lightning-fast USB 3.1
  • 5X Protection II – Advanced hardware safeguards for all-round protection
  • Ultimate 10Gbit/s USB 3.1 Gen 2 onboard
  • Epic gaming audio with LED-illuminated shielding
  • Media-acclaimed UEFI BIOS with EZ Flash 2
Advanced Hardware Safeguards
Industry-leading 5X Protection II employs the finest components, excellent circuit design, and exacting standards to guarantee quality and long-term durability of your motherboard with all-round protection. For you, that means exceptional protection and stability for your build — the result of decades of engineering experience from the world's leading motherboard brand.
LANGuard
Pumped-up throughput. 2.5X higher surge tolerance.
ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors ensuring a more reliable connection and better throughput, plus electrostatically-guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges.
DRAM Overcurrent Protection
Short-circuit damage prevention
Onboard resettable fuses prevent overcurrent and short-circuit damage. This extends beyond I/O ports to DRAM to safeguard the lifespan of both your system and connected devices.
DIGI+ VRM
Precision control for stable power
ASUS-exclusive DIGI+ VRM intelligently delivers power to the processor based on real-time demands, reducing energy waste and improving system stability.
Stainless-Steel Back I/O
3X corrosion-resistance for greater durability
Corrosion-resistant stainless steel back I/O panels bonded with chromium oxide have a lifespan that's three times (3X) longer than ordinary panels.
ESD Guards
Electrostatic discharge (ESD) can happen suddenly, and its damaging effects are easily underestimated. ASUS ESD Guards are tested to very high standards, capable of up to +/- 10kV for air discharge and +/-6kV for contact discharge. We employ an active protective circuit design to guard your system against electrostatic interference and damage, providing greater component longevity.
LAN port
ESD TVS diode protection on the LAN circuit.
USB connectors
TVS diodes for surface-mount and dual-inline packages.
VGA connectors
Additional on-circuit ESD TVS diodes to protect D-Sub functionality.
Keyboard and mouse connectors
Additional on-circuit ESD transient-voltage-suppression (TVS) diodes.
The smoothest, slickest mouse-controlled graphical BIOS has been improved to make it even more appealing. Whether you're a PC novice or a seasoned overclocker, the EZ and Advanced Modes help you find your way, quickly and easily.
ASUS A88X-PLUS/USB 3.1 - motherboard - ATX - Socket FM2+ - AMD A88X
Motherboard - ATX
Chipset Type
AMD A88X
Processor Socket
1 x Socket FM2+
Compatible Processors
Athlon, A series (supports CPUs with up to 4 cores)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
8 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.1 Gen 2 + 2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Max Allocated RAM Size
2 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
AMD A88X
Processor Socket
Socket FM2+
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1866 MHz, 2133 MHz, 2400 MHz (O.C.), 2200 MHz (O.C.), 2250 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, AMD Memory Profile (AMP)
Graphics
2 GB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 (FM2+ processor must be installed) , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCIe x1 , 3 x PCI
Storage Interfaces
SATA-600 -connectors: 8 x 7pin Serial ATA - 8 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 / JBOD
1 x LAN (Gigabit Ethernet) , 1 x PS/2 keyboard / mouse , 1 x DVI , 1 x HDMI , 1 x VGA , 2 x USB 3.0 , 2 x USB 2.0 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 2 x USB 3.1 Gen 2
Internal Interfaces
6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x SPDIF out - header , 1 x serial - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, UEFI BIOS, SMBIOS 2.7 support
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, ASUS Q-Design, ESD Guards, ASUS TurboV EVO, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Fan Xpert, ASUS DIGI+ VRM, Fanless Design Heatsink, AMD Radeon Dual Graphics, AMD Quad CrossFireX technology support, Disk Unlocker, AMD Turbo CORE 3.0 technology, AMD Memory Profile (AMP) support, ASUS Enhanced DRAM Overcurrent Protection, ASUS Stainless Steel Back I/O, LANGuard, USB 3.1 Boost, ASUS 5X Protection II
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Charger+, ASUS Update, ASUS AI Suite III, Antivirus (OEM version), Mobo Connect, PC Cleaner
Plug and Play, ACPI 2.0a
30.5 cm
22.6 cm
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.63
Scroll to top
