BT.com
Wishlist
ASRock Z97 EXTREME4 S1150 Intel Z97 DDR3 ATX
Delivery
Standard Due date unavailable
XXL Aluminum Alloy Heatsink Design.
The extra large aluminum alloy heatsinks take away heat dramatically. As the MOSFETs and chipsets areas are well covered by these heatsinks to protect them from overheating, CPU and chipsets can perform with lower temperature, and your motherboard and system will be more stable and reliable.
Premium Alloy Choke.
The new generation alloy chokes effectively increase up to 90% saturation current and feature a highly magnetic and heat resistant design, making the motherboard more efficient, stable and reliable.
Dual-Stack MOSFET for CPU Power.
Dual-Stack MOSFET (DSM) is another innovative MOSFETs design by ASRock. The silicon die area is increased by stacking two dies into one MOSFET. The larger the die area, the lower Rds(on). Compared to traditional discrete MOSFET, DSM with larger die area provides extreme lower Rds(on) 1.2 mO, so the power supply for the CPU Vcore is more efficient.
NexFET MOSFET for Memory Power.
The next generation NexFET MOSFETs control the power supply to DRAM slots more efficiently. They provide lower RDS(on) 2.9 mO, delivering higher efficiency and lower temperature.
12K Platinum Caps.
Supreme 12K platinum capacitors with lifespans of at least 12,000 hours. Compared to other counterparts on high-end motherboards that merely have lifespans of around 10,000 hours, these platinum capacitors have 20% longer lifespans and provide more stability and reliability.
Sapphire Black PCB.
ASRock does not overlook any details, even those tiny ones. With pure black PCB appearance, the new Sapphire Black PCB represents rock-solid quality and gives the motherboard a more mysterious touch.
ASRock - motherboard - LGA1150 Socket
Motherboard
Processor Socket
1 x LGA1150 Socket
RAM Supported
DDR3 , non-ECC , unbuffered
Motherboard
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
High Definition Audio
Power Connectors
24-pin main power connector
BIOS Type
AMI
Sleep / Wake Up
Wake on LAN (WOL)
Scroll to top
