BT.com
Wishlist
ASRock Z87 Extreme6 S1150 Intel Z87 DDR3 ATX
Delivery
Standard Due date unavailable
This motherboard supports remote wake with the onboard Intel LAN, so you can connect with your PC from anywhere in the world. You will be able to power your PC on or turn it off, monitor and take control of it remotely with another smartphone, tablet or computer.
Purity Sound is a combination of several hardware, software audio solutions and technologies that will satisfy even the pickiest audiophiles. Including 7.1 CH HD audio with Realtek ALC1150 audio codec, 115 dB SNR DAC with Differential Amplifier, TI 5532 Premium Headset Amplifier which supports up to 600 ohm headphones, cap less Direct Drive technology, EMI shielding cover, PCB isolate shielding and support for DTS Connect.
ASRock Z87 Extreme6 - motherboard - ATX - LGA1150 Socket - Z87
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Xeon, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
6 x SATA-600 (RAID), 4 x SATA-600, 1 x eSATA-600
USB / FireWire Ports
4 x USB 3.0 + 2 x USB 2.0 + ( 4 x USB 3.0 + 4 x USB 2.0 via headers )
Max Allocated RAM Size
1792 MB
Audio
HD Audio (8-channel)
LAN
2 x Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
2400 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz, 2800 MHz, 2933 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1792 MB
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Controller
Intel I211-AT / I217V
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 3 x PCIe 3.0 x16 ( dual: x8 mode; triple: x8, x4, x4 mode; single card: x16 mode ) , 1 x PCIe 2.0 x1 , 1 x Mini PCIe , 2 x PCI
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 4 x 7pin SATA, 1 x 7pin eSATA - 4 devices
RAID Features
Intel Rapid Storage Technology
1 x PS/2 keyboard / mouse , 1 x DVI-I , 2 x HDMI , 1 x DisplayPort , 1 x TOSLINK , 2 x USB 2.0 , 4 x USB 3.0 , 2 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
2 x USB 3.0 - header , 2 x USB 2.0 - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
SMBIOS 2.3.1. support, ACPI 1.1 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
ASRock Hybrid Booster, ASRock U-COP, NVIDIA SLI Technology Support, 12 Phase Power Design, ASRock Instant Flash, ASRock CPU Frequency Stepless Control, ASRock Boot Failure Guard (B.F.G.), Teaming Technology, HDCP compliant, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASRock APP Charger, Intel Turbo Boost Technology 2.0, ASRock Good Night LED, Intel Clear Video HD Technology, ASRock XFast USB, Intel Smart Response Technology, Conductive Polymer Capacitors, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASRock OMG (Online Management Guard), ASRock Internet Flash, Digi Power Design, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ASRock Dehumidifier Function, Dual-Stack MOSFET (DSM), ASRock Interactive UEFI, ASRock Fast Boot, ASRock Restart to UEFI, ASRock UEFI System Browser
I/O back plate, rear USB 3.0 bracket, ASRock SLI_Bridge_2S Card, front USB 3.0 panel with 2.5" HDD/SSD rack
6 x Serial ATA cable
Software Included
Drivers & Utilities, Cyberlink MediaEspresso 6.5 (30-day trial)
WHQL, FCC, EuP Ready, ErP Ready
Scroll to top
