BT.com
Wishlist
ASRock Z270M Pro4 LGA1151 Intel Z270 DDR4 mATX
ASRock Z270M Pro4 LGA1151 Intel...
£102.42
£102.42
Add to wishlist
Delivery
Standard Due date unavailable
Armor Your VR Machine
Prepare yourself well to enjoy the impressive world of Virtual Reality. Before that, you have to make sure everything is qualified, including hardware, software and drivers. Motherboard is the key to connect every critical components and ASRock’s VR Ready motherboards are definitely the one you’re looking for. The premium qualify is assured by rigorous testing during development. The sturdy components and rock-slid performance makes you completely immersive in the VR scenario. Users can be assured to experience VR enjoyments without any compatibility problems.
Dual Ultra M.2 For SSD
Two of the world’s fastest PCIe Gen3 x4 Ultra M.2 slots that deliver up to 32Gb/s transfer speed, it also supports SATA3 6Gb/s M.2 modules.
Intel® LAN
Intel® LAN provides the best throughput performance, lower CPU utilization, enhanced stability and is able to deliver ultimate network experience to users!
Intel® Optane™ Memory Ready
Supports Intel® Optane™ memory technology and Intel® Optane™ storage technology that redeflnes a new standard of high performance and responsiveness.
ASRock Intel® 4-Layer Memory POOL Technology
POOL (Planes On Outer Layers) technology allows 4-layer boards to utilize stripline routing instead of micro-strip routing, making motherboard having better electrical properties and performance.
USB Type-C
A latest reversible USB Type-C design that flfits the connector either way.
ASRock Z270M Pro4 - motherboard - micro ATX - LGA1151 Socket - Z270
Motherboard - micro ATX
Chipset Type
Intel Z270 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2400 MHz (O.C.), 3200 MHz (O.C.), 3600 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP) 2.0
Graphics
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
Audio Codec
Realtek ALC892
High Definition Audio, Premium Blu-ray audio support
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x Ultra M.2
RAID Features
Intel Rapid Storage Technology
1 x PS/2 keyboard , 4 x USB 3.0 , 1 x HDMI , 1 x DVI-D , 1 x LAN (Gigabit Ethernet) , 1 x PS/2 mouse , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x VGA , 1 x USB-C , 1 x audio line-out - mini-jack , 1 x USB 2.0
Internal Interfaces
2 x USB 3.0 - header , 2 x USB 2.0 - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
UEFI BIOS, SMBIOS 2.7 support, ACPI 6.0 support
Manual Settings
Processor core voltage, memory voltage
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, opened case detection
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
Chassis intrusion detection, ASRock Instant Flash, HDCP compliant, 15µ Gold Contact, ASRock APP Charger, 6 Phase Power Design, Intel Turbo Boost Technology 2.0, Intel Clear Video HD Technology, Intel Smart Response Technology, ASRock XFast LAN, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, ASRock Internet Flash, Digi Power Design, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ESD Protection, ASRock UEFI System Browser, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), ASRock UEFI Tech Service, 4K resolution support, Supports Intel K-Series unlocked CPU, ASRock BCLK, ELNA Audio Capacitors, ASRock A-Tuning, ASRock Full Spike Protection, ASRock APP Shop, ASRock Super Alloy, High Density Glass Fabric PCB, ASRock Full HD UEFI, ASRock My Favorites in UEFI, ASRock Easy RAID Installer, Sapphire Black PCB, ASRock Live Update, ASRock EZ Mode, ASRock Ultra M.2, Premium 50A Power Choke, ASRock Intel 4-Layer Memory POOL (Planes on Outer Layers) Technology, ASRock OBR (OS Backup & Recovery)
I/O back plate, 2 x M.2 screws
2 x Serial ATA cable
Software Included
Drivers & Utilities, Antivirus (Trial version), Google Chrome Browser, Google ChromeToolbar
BSMI, WHQL, FCC, EuP Ready, ErP Ready, RCM
24.4 cm
24.4 cm
£102.42
Save on this ideal PC Build kit!
Save £8.43
£121.64
Scroll to top
