BT.com
Wishlist
ASRock Z270M Extreme4 LGA1151 Intel Z270 DDR4 mATX
ASRock Z270M Extreme4 LGA1151 Intel...
£140.82
£140.82
Add to wishlist
Delivery
Standard Due date unavailable
Armor Your VR Machine
Prepare yourself well to enjoy the impressive world of Virtual Reality. Before that, you have to make sure everything is qualified, including hardware, software and drivers. Motherboard is the key to connect every critical components and ASRock’s VR Ready motherboards are definitely the one you’re looking for. The premium qualify is assured by rigorous testing during development. The sturdy components and rock-slid performance makes you completely immersive in the VR scenario. Users can be assured to experience VR enjoyments without any compatibility problems.
AURA RGB LED
Build your own colorful lighting system! AURA RGB LED and header allows users to connect LED strip and create their unique PC style easily.
Dual Ultra M.2 For SSD
Two of the world’s fastest PCIe Gen3 x4 Ultra M.2 slots that deliver up to 32Gb/s transfer speed, it also supports SATA3 6Gb/s M.2 modules.
2 PCI-E STEEL SLOT: Tailor-made for multiple VGA cards
Adopts PCI-E Steel Slot, which is built with more solder points on the PCB for better performance and preventing any signal interference with graphics cards. Allows your graphics cards with enhanced signals and to be well-installed in the PCI-Express slot.
Dual USB 3.1 (Type-A + Type-C)
This motherboard has a pair of onboard Type-A and Type-C USB 3.1 ports built on the rear i/o for supporting next generation USB 3.1 devices and to deliver up to 10 Gbps data transfer rates.
Purity Sound 4
It's time to enjoy the most purified audio performance with ultra high definition. Purity Sound4 is a combination of several hardware, software audio solutions. 7.1 CH HD audio with the latest Realtek ALC1220 audio codec, individual PCB layers for R/L audio channel, 120dB SNR DAC and other technologies to deliver the crispest sound effects.
  • 120dB SNR DAC
  • Gold Audio connector
  • TI® NE5532 Premium Headset Amplifier
  • Individual PCB Layers for R/L Audio Channel
  • Impedance Sensing on Front Out port
  • PCB Isolate Shielding
  • Pure Power-In
  • Nichicon Fine Gold Series Audio Caps
ASRock Z270M Extreme4 - motherboard - micro ATX - LGA1151 Socket - Z270
Motherboard - micro ATX
Chipset Type
Intel Z270 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2400 MHz (O.C.), 3200 MHz (O.C.), 3600 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP) 2.0
Graphics
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
Audio Codec
Realtek ALC1220
DTS Connect, High Definition Audio, Premium Blu-ray audio support, Purity Sound 4
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 3 x PCIe 3.0 x16 , 1 x PCIe 3.0 x1 , 1 x M.2 socket (Key E)
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x Ultra M.2
RAID Features
Intel Rapid Storage Technology
1 x PS/2 keyboard / mouse , 4 x USB 3.0 , 1 x HDMI , 1 x DVI-D , 1 x LAN (Gigabit Ethernet) , 1 x SPDIF out , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x VGA , 1 x USB-C , 1 x audio line-out (front surround) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x USB 3.1
Internal Interfaces
4 x USB 3.0 - header , 4 x USB 2.0 - header , 1 x audio - header , 1 x serial - header , 2 x Thunderbolt , 1 x USB 3.0 - Type A
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
UEFI BIOS, SMBIOS 2.7 support, ACPI 6.0 support
Manual Settings
Processor core voltage, memory voltage
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, opened case detection
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
NVIDIA SLI Technology Support, ASRock Instant Flash, NVIDIA Quad SLI Technology Support, ASRock APP Charger, 6 Phase Power Design, Intel Turbo Boost Technology 2.0, ASRock XFast LAN, ASRock Crashless BIOS, AMD Quad CrossFireX technology support, ASRock Internet Flash, Digi Power Design, ESD Protection, ASRock UEFI System Browser, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), ASRock UEFI Tech Service, Supports Intel K-Series unlocked CPU, ASRock BCLK, ASRock Full Spike Protection, ASRock APP Shop, ASRock Super Alloy, High Density Glass Fabric PCB, ASRock Full HD UEFI, ASRock My Favorites in UEFI, ASRock Easy RAID Installer, ASRock Live Update, ASRock EZ Mode, AURA RGB Lighting Control, ASRock Ultra M.2, ASRock Hyper BCLK Engine II, ASRock Intel 4-Layer Memory POOL (Planes on Outer Layers) Technology, ASRock Steel Slots
I/O back plate, 3 x M.2 screws, ASRock SLI_HB_Bridge_1S Card
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASRock A-Tuning, Antivirus (Trial version), Google Chrome Browser, Google ChromeToolbar
WHQL, FCC, EuP Ready, ErP Ready
24.4 cm
24.4 cm
£140.82
Save on this ideal PC Build kit!
Save £8.43
£160.04
Scroll to top
