BT.com
Wishlist
ASRock Z170 Pro4 Intel Z170 LGA1151 DDR4 PCIe M.2 USB3.0 ATX
ASRock Z170 Pro4 Intel Z170 LGA1151...
£100.60
£100.60
Add to wishlist
Delivery
Standard Due date unavailable
Z170 Pro4 - Entry level Z170 motherboard with an Ultra M.2 slot
  • ASRock Super Alloy
  • Supports 6th Generation Intel® Core™ Processors (Socket 1151)
  • Digi Power, 10 Power Phase Design
  • Supports Dual Channel DDR4 3200+(OC)
  • 2 PCIe 3.0 x16, 3 PCIe 3.0 x1
  • AMD Quad CrossFireX™, CrossFireX™
  • Graphics Output Options: DVI-D, HDMI
  • 7.1 CH HD Audio (Realtek ALC892 Audio Codec), ELNA Audio Caps
  • 2 SATA Express, 6 SATA3, 1 Ultra M.2 (PCIe Gen3 x4 & SATA3)
  • 8 USB 3.0 (2 Front, 6 Rear)
  • Supports Full Spike Protection, ASRock Live Update & APP Shop
ASRock Z170 Pro4 - motherboard - ATX - LGA1151 Socket - Z170
Motherboard - ATX
Chipset Type
Intel Z170 Express
Processor Socket
LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4 , non-ECC , unbuffered
Storage Ports
8 x SATA-600 (RAID), 2 x SATA Express port, 1 x Ultra M.2
Max Allocated RAM Size
1792 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z170 Express
Processor Socket
LGA1151 Socket
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2400 MHz (O.C.), 3200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP) 2.0
Graphics
1792 MB
Audio
Audio Codec
Realtek ALC892
High Definition Audio, Premium Blu-ray audio support
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 ( x16 mode ) , 1 x PCIe 3.0 x16 ( x4 mode ) , 3 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Rapid Storage Technology
1 x PS/2 keyboard / mouse , 6 x USB 3.0 , 1 x HDMI , 1 x DVI-D , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
1 x USB 3.0 - header , 2 x USB 2.0 - header , 1 x audio - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
SMBIOS 2.3.1. support, ACPI 1.1 support, UEFI BIOS
Manual Settings
Processor core voltage, memory voltage
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
ASRock Instant Flash, Intel Turbo Boost Technology 2.0, Intel Smart Response Technology, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, ASRock OMG (Online Management Guard), ASRock Internet Flash, Digi Power Design, ASRock Dehumidifier Function, ASRock Fast Boot, ASRock UEFI System Browser, ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, 4K resolution support, Supports Intel K-Series unlocked CPU, ASRock BCLK, ELNA Audio Capacitors, ASRock Full Spike Protection, ASRock APP Shop, ASRock Super Alloy, High Density Glass Fabric PCB, ASRock Full HD UEFI, ASRock My Favorites in UEFI, ASRock Easy RAID Installer, Nichicon 12K Platinum Caps, I/O Armor, ASRock Live Update, 10 Phase Power Design
I/O back plate, 1 x M.2 screw
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASRock A-Tuning, ASRock Disk Health Report
WHQL, FCC, ACPI 1.1, EuP Ready, ErP Ready
Scroll to top
