BT.com
Wishlist
ASRock Z170 Extreme4 Intel Z170 LGA1151 DDR4 PCIe M.2 USB3.1 ATX
Delivery
Standard Due date unavailable
Z170 Extreme4 - Mainstream Z170 motherboard with SLI
  • ASRock Super Alloy
  • Supports 6th Generation Intel® Core™ Processors (Socket 1151)
  • Digi Power, 10 Power Phase Design
  • Supports Dual Channel DDR4 3200+(OC)
  • 3 PCIe 3.0 x16, 3 PCIe 3.0 x1
  • NVIDIA® Quad SLI™, AMD 3-Way CrossFireX™
  • Graphics Output Options: DVI-D, HDMI, DisplayPort 1.2
  • Supports Triple Monitor
  • 7.1 CH HD Audio (Realtek ALC1150 Audio Codec), Supports Purity Sound™ 3 & DTS Connect
  • 3 SATA Express, 6 SATA3, 1 Ultra M.2 (PCIe Gen3 x4 & SATA3)
  • 2 USB 3.1 (1 Type-C & 1 Type-A), 8 USB 3.0 (2 Front, 6 Rear)
  • Supports Full Spike Protection, ASRock Live Update & APP Shop
ASRock Z170 Extreme4 - motherboard - ATX - LGA1151 Socket - Z170
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 3 x SATA Express port, 1 x M.2
USB / FireWire Ports
1 x USB-C + 1 x USB 3.1 + 6 x USB 3.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2400 MHz (O.C.), 3200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP) 2.0
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 3 x PCIe 3.0 x16 , 3 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin SATA, 1 x M.2, 3 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Rapid Storage Technology
1 x PS/2 keyboard / mouse , 6 x USB 3.0 , 1 x HDMI , 1 x DVI-D , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x SPDIF out , 1 x DisplayPort , 1 x USB-C , 1 x USB 3.1
Internal Interfaces
2 x USB 2.0 - header , 1 x USB 3.0 - header , 1 x audio - header , 1 x Thunderbolt - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
SMBIOS 2.3.1. support, ACPI 1.1 support, UEFI BIOS
Manual Settings
Processor core voltage, memory voltage
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
ASRock Instant Flash, Intel Turbo Boost Technology 2.0, Intel Smart Response Technology, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, ASRock OMG (Online Management Guard), ASRock Internet Flash, Digi Power Design, ASRock Dehumidifier Function, ASRock Fast Boot, ASRock UEFI System Browser, ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, 4K resolution support, Supports Intel K-Series unlocked CPU, ASRock BCLK, ELNA Audio Capacitors, ASRock Full Spike Protection, ASRock APP Shop, ASRock Super Alloy, High Density Glass Fabric PCB, ASRock Full HD UEFI, ASRock My Favorites in UEFI, ASRock Easy RAID Installer, Nichicon 12K Platinum Caps, I/O Armor, ASRock Live Update, 10 Phase Power Design
I/O back plate, 1 x M.2 screw
4 x Serial ATA cable , 1 x SLI bridge , 1 x Serial ATA power adapter , 1 x USB power cable
Software Included
Drivers & Utilities, ASRock A-Tuning, ASRock Disk Health Report
WHQL, FCC, ACPI 1.1, EuP Ready, ErP Ready
Scroll to top
