BT.com
Wishlist
ASRock X99M Extreme4 Intel LGA2011-3 X99 mATX DDR4 RAID Gigabit LAN
Delivery
Standard Due date unavailable
The extra large aluminum alloy heatsinks take away heat dramatically. As the MOSFETs and chipsets areas are well covered by these heatsinks to protect them from overheating, MOSFET and chipsets can perform with lower temperature, and your motherboard and system will be more stable and reliable. Specially designed for memory power delivery, the alloy chokes feature a highly magnetic and heat resistant design, thus delivering more stable and reliable power to the motherboard.
ASRock does not overlook any details, even those tiny ones. With PCB appearance, the Sapphire PCB represents rock-solid quality and gives the motherboard a more mysterious touch.
ASRock X99M Extreme4 - motherboard - micro ATX - LGA2011-v3 Socket - X99
Motherboard - micro ATX
Chipset Type
Intel X99 Express
Processor Socket
1 x LGA2011-v3 Socket
Compatible Processors
Xeon, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4 , non-ECC, ECC , registered, unbuffered
Storage Ports
6 x SATA-600 (RAID), 4 x SATA-600, 1 x eSATA-600, 1 x Ultra M.2
USB / FireWire Ports
4 x USB 3.0 + 4 x USB 2.0 + ( 2 x USB 3.0 + 4 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel X99 Express
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
1
Xeon, Core i7
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Registered, unbuffered
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
Realtek ALC1150
DTS Connect, High Definition Audio, Premium Blu-ray audio support
LAN
Network Controller
Intel I218V / Atheros AR8171
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 ( x4 mode ) , 1 x Ultra M.2
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices , SATA-600 -connectors: 1 x 7pin external SATA - 1 devices
RAID Features
Intel Rapid Storage Technology
1 x PS/2 keyboard / mouse , 4 x USB 2.0 , 2 x LAN (Gigabit Ethernet) , 1 x SPDIF out , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 4 x USB 3.0
Internal Interfaces
2 x USB 3.0 - header , 4 x USB 2.0 - header , 1 x audio , 1 x serial , 1 x Thunderbolt
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
Multilingual BIOS, SMBIOS 2.3.1. support, ACPI 1.1 support, Untied Overclocking Technology, Dual BIOS, Secure Backup UEFI Technology
Manual Settings
CPU frequency, memory voltage
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
12 Phase Power Design, ASRock Instant Flash, 15µ Gold Contact, Intel Turbo Boost Technology 2.0, ASRock XFast LAN, ASRock Dr. Debug, NVIDIA 4-way SLI Technology Support, ASRock XFast RAM, ASRock Crashless BIOS, ASRock OMG (Online Management Guard), ASRock Internet Flash, Digi Power Design, AMD 4-way CrossFireX technology support, ASRock Dehumidifier Function, ESD Protection, ASRock Restart to UEFI, ASRock UEFI System Browser, Platform Controller Hub (PCH) 1.05V Voltage Multi-adjustment, Platform Controller Hub (PCH) 1.5V Voltage Multi-adjustment, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, Premium Headset Amplifier, Direct Drive Technology, EMI shielding cover, NexFET, ASRock A-Tuning, ASRock Full Spike Protection, ASRock Cloud, ASRock APP Shop, ASRock Super Alloy, ASRock Purity Sound 2, ASRock HDD Saver Technology, ASRock Easy RAID Installer, Sapphire Black PCB, Ultra Dual-N MOSFET (UDM)
HDD saver cable
2 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, Antivirus (Trial version), Start8 (30 days trial), Google Chrome Browser, Google ChromeToolbar, Orbweb.ME Professional, ASRock Disk Health Report
WHQL, FCC, EuP Ready, ErP Ready
Scroll to top
