Click to visit BT.com
BT.com
Wishlist
ASRock X79 Extreme4-M S2011 X79 Intel DDR3 mATX
4.0*
Quicklinx: 7TBBWS00
Mfr#: X79-EXTREME4-M
Essential accessories
  • Premium Gold Caps (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
  • Intel® Core™ i7 processor family for the LGA 2011 Socket
  • Supports Quad Channel DDR3 2400+(OC)
  • Digi Power, Advanced 6 + 2 Power Phase Design
  • 3 x PCIe 3.0 x16 Slots, Supports AMD 3-Way CrossFireX™ and NVIDIA® 3-Way SLI™
  • Dr. Debug, Smart Switch Design: Power/Reset/Clear CMOS Switch with LED
  • Supports ASRock XFast LAN, XFast Charger, XFast USB, XFast RAM Technologies
  • Supports graphical UEFI, AXTU, SmartView, APP Charger
  • 7.1 CH HD Audio with Content Protection (Realtek ALC898 Audio Codec), Supports THX TruStudio™
  • Free Bundle : ASRock X-FAN, CyberLink MediaEspresso 6.5 Trial, ASRock MAGIX Multimedia Suite
Digi Power: More Precise, More Efficient
By adopting digital pulse-width modulation (PWM), the ASRock motherboard can provide CPU Vcore voltage more efficiently and smoothly. Compared to analog PWM, digital PWM can optimize the CPU power solution and provide a proper and stable Vcore for the processor.
Next-Gen PCI-E 3.0 Support
The ASRock motherboards support the Next-Gen PCI-E 3.0! PCI Express 3.0 can maximize the bandwidth for the next-gen PCI Express 3.0 VGA cards, provide ultimate graphics performance.
  • Higher bit rate - 8.0GT/s
  • Higher bandwidth per lane - 1GB/s
  • Higher efficiency - 98.5% encoding efficiency
  • 100% backward compatible with previous PCI-E 2.0 / 1.0 standard
FAN: The Smart Cooling Design
Greater air flow, faster heat dissipation! ASRock X-FAN allows the motherboard to breathe smoothly. It will be automatically activated only when the system rises to a certain temperature under heavy-loading. Normally, ASRock X-FAN will remain deactivated to give users the quietest computing experience.
ASRock X79 Extreme4-M - motherboard - micro ATX - LGA2011 Socket - X79
Motherboard - micro ATX
Chipset Type
Intel X79 Express
Processor Socket
1 x LGA2011 Socket
Compatible Processors
Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
2 x SATA-600 (RAID), 1 x SATA-600, 4 x SATA-300 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 1 x FireWire + 6 x USB 2.0 + ( 2 x USB 3.0 + 1 x FireWire + 4 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Intel X79 Express
Processor Socket
LGA2011 Socket
Max Processors Qty
1
Core i7
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
2400 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 800 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
Realtek ALC898
THX TruStudio PC, High Definition Audio
LAN
Network Controller
Broadcom BCM57781
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 3 x PCIe 3.0 x16 , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061 : SATA-600 -connectors: 3 x 7pin SATA - 3 devices , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 1 x 7pin external SATA - 1 devices
RAID Features
Intel Rapid Storage Technology
1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x SPDIF , 1 x TOSLINK , 6 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x FireWire - 6 pin FireWire , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (front surround) - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
1 x serial , 1 x SPDIF , 1 x FireWire , 4 x USB 2.0 , 2 x USB 3.0
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
JumperFree, SMBIOS 2.3.1. support, Hyper-Threading Technology, ACPI 1.1 support, Untied Overclocking Technology, UEFI BIOS
Manual Settings
CPU frequency, processor core voltage, memory bus frequency
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer, north bridge fan tachometer
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
ASRock Hybrid Booster, ASRock U-COP, ASRock Instant Boot, NVIDIA SLI Technology Support, 8 Phase Power Design, ASRock Instant Flash, All-Solid Capacitor motherboard Design, ASRock Boot Failure Guard (B.F.G.), NVIDIA Quad SLI Technology Support, ASRock APP Charger, Intel Turbo Boost Technology 2.0, ASRock Good Night LED, ASRock SmartView, ASRock XFast USB, ASRock XFast LAN, ASRock Dr. Debug, ASRock XFast Charger, ASRock XFast RAM, ASRock X-FAN, ASRock Smart Switch, AMD CrossFireX technology support, AMD Quad CrossFireX technology support
I/O back plate, ASRock SLI_Bridge_2S Card
Software Included
Drivers & Utilities, ASRock Software Suite, ASRock Extreme Tuning Utility, Cyberlink MediaEspresso 6.5 (30-day trial)
Plug and Play, WHQL, FCC, EuP Ready, ErP Ready
24.4 cm
24.4 cm
Customer reviews
Write a review for the ASRock X79 Extreme4-M S2011 X79 Intel DDR3 mATX here!
Awesome Mother board
Reviewed by Chris. Review Posted 15/02/2013
Love the mother board just what I need for my M-ATX case WARNING!!!! As soon as you get this mother board check the BIOS number as mine came with v1.10 and there now at 2.70 and because it was an old BIOS it did not recognise a USB mouse or the NEW i7's and it some times did not boot and gave an AF error on the board and according to the instruction book it means "exiting startup" all you need to do is download the new BIOS from this: http://www.asrock.com/mb/Intel/X79%20Extreme4-M/?cat=Download&os=BIOS Put it on a USB and you are all good :D WARNING!!!!
  • Overall 4*
  • Ease of use 5*
  • Value for money 4*
AsRock Extreme4-M X79
Reviewed by Jack Leigh. Review Posted 10/05/2013
Brilliant motherboard, very easy to install and came with everything you need. One problem however. I have just built a PC with this motherboard and an i7-3280 and upon booting for the first time received an AF Error code. This is an outdated BIOS chip error and will only give you a black screen. All you have to do is phone AsRock and they will send you out an updated BIOS chip at no extra charge. ASRock EUROPE B.V. Phone: +31-24-345-44-33 ASRock America, Inc. Phone: +1-909-590-8308 Remember to replace the + with 00 if phoning from the UK. Even with this slight technical hitch it's still worth the cash. Just remember to phone them ASAP if you're planning a build with an i7-3280.PS: I phoned AMERICA to find this out.
  • Overall 4*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
