Click to visit BT.com
BT.com
Wishlist
ASRock X79 Extreme 11 S2011 Intel X79 DDR3 ATX
Quicklinx: 87XQWS00
Mfr#: X79 EXTREME11
Essential accessories
X79 Extreme11: The emperor of X79 Chipset Motherboard
  • 7 x PCIe 3.0 x16 slots (2 x PLX PEX 8747 bridges), Support 4-Way SLI/CrossFireX in full x16 PCIe 3.0 speed
  • 8 SAS2/SATA3 from LSI™ SAS 2308 PCIe 3.0 Controller
  • Creative Sound Core3D 7.1 CH, Supports Premium Headset Amplifier, THX TruStudio PRO™
  • Premium Gold Caps (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
  • Supports Dual-Stack MOSFET (DSM)
  • Supports Digi Power, 24 + 2 Power Phase Design
  • Supports Quad Channel DDR3 2500+(OC)
  • Broadcom PCIE Dual LAN with Teaming Function
  • 8 USB 3.0 (4 Front, 4 Back), 10 SATA3 (2 from Intel® X79, 8 from LSI)
  • Supports XFast 555, OMG, Internet Flash, Easy RAID Installer, Interactive UEFI, UEFI System Browser
  • Free Bundle : 1 x Front USB 3.0 Panel, 1 x Rear USB 3.0 Bracket, CyberLink MediaEspresso 6.5 Trial, MAGIX Multimedia Suite
4-Way SLI/CrossFireX at PCIe 3.0 x16 Speed: Supported by 2 PLX PEX 8747 Bridge
PLX PEX 8747 bridge is a PCIe Gen3 silicon chip. It brings solid PCIe 3.0 lanes for PCIe devices and is optimized to support high performance graphics. Enthusiasts will appreciate the onboard two PLX PEX 8747 bridges. Via PLX PEX bridges, ASRock X79 Extreme11 can run multi-GPU 4-Way SLI/CrossFireX at PCIe Gen3 x16/x16/x16/x16 mode simultaneously.
8 SAS2/SATA3 (6 Gb/s) from LSI™ SAS 2308 PCIe 3.0 Controller
The feature-rich X79 Extreme11 motherboard offers rich storage options. It provides 10 SATA3 ports, 8 of which are SAS2 (6 Gb/s) ports sourced from LSI™ SAS 2308 PCIe 3.0 controller. Via LSI™ MegaRAID® utility, users can get high transfer speed 3.8 GB/s through 8 SSDs in RAID 0 mode.
Creative Sound Core3D Audio with Premium Headset Amplifier
The onboard Creative SoundCore 3D quad-core sound and voice processor brings a truly immersive audio experience and supports THX TruStudio PRO™, CrystalVoice, EAX 1.0 to 5.0, etc. ASRock Premium Headset Amplifier (PHA) provides wider bandwidth, higher slew rate with lower noise and distortion. It also supports up to 250 Ohm high-end headsets, which delivers crisper audio into the users ears.
Scout Mode™: Hear the enemy before they hear you
Scout Mode™ technology is a proprietary technology that allows you to hear your enemies from further away, giving you a distinct tactical advantage in combat.
Dual-Stack MOSFET (DSM) is an innovative new design of MOSFETs. The silicon die area is increased by stacking two dies into a MOSFET. The larger the die area, the lower Rds(on). Compared to traditional discrete MOSFET, DSM can provide larger die area and lower Rds(on), so the power supply for CPU Vcore is more efficient.
Premium Gold Caps: Top-Class Quality Guaranteed
Premium Gold Caps are luxury capacitors. These 100% Japan-made solid capacitors are sleek, high gloss caps with a premium gold coating representing long life and stable performance.
Next-Gen PCI-E 3.0 Support
The ASRock motherboards support the Next-Gen PCI-E 3.0! PCI Express 3.0 can maximize the bandwidth for the next-gen PCI Express 3.0 VGA cards, provide ultimate graphics performance.
  • Higher bit rate - 8.0GT/s
  • Higher bandwidth per lane - 1GB/s
  • Higher efficiency - 98.5% encoding efficiency
  • 100% backward compatible with previous PCI-E 2.0 / 1.0 standard
8 x USB 3.0 (4 Front, 4 Back)
Rich storage options! This motherboard offers 8 USB 3.0 (4 from onboard header, 4 from rear I/O) and bundles an exclusive front USB 3.0 panel to facilitate computing environment.
ASRock X79 Extreme11 - motherboard - ATX - LGA2011 Socket - X79
Motherboard - ATX
Chipset Type
Intel X79 Express
Processor Socket
1 x LGA2011 Socket
Compatible Processors
Core i7
Max RAM Size
64 GB
RAM Supported
8 DIMM slots - DDR3 , non-ECC, ECC , unbuffered
Storage Ports
8 x SAS2 (RAID), 2 x SATA-600 (RAID), 4 x SATA-300 (RAID), 2 x eSATA-600
USB / FireWire Ports
4 x USB 3.0 + 1 x FireWire + 8 x USB 2.0 + ( 4 x USB 3.0 + 1 x FireWire + 6 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
2 x Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel X79 Express
Processor Socket
LGA2011 Socket
Max Processors Qty
1
Core i7
Supported RAM
Max Size
64 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
EAX 1.0, EAX 5.0, High Definition Audio, THX TruStudio Pro
LAN
Network Controller
Broadcom BCM57781
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 240-pin , 7 x PCIe 3.0 x16
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , LSI Logic LSISAS2308 : SAS 2 -connectors: 8 - 8 devices - RAID 0 / RAID 1 / RAID 1E / RAID 10 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin external SATA - 2 devices
RAID Features
Intel Rapid Storage Technology
1 x PS/2 keyboard , 1 x TOSLINK , 8 x USB 2.0 , 4 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x FireWire - 6 pin FireWire , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
1 x FireWire , 6 x USB 2.0 , 4 x USB 3.0
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
JumperFree, SMBIOS 2.3.1. support, Hyper-Threading Technology, ACPI 1.1 support, Untied Overclocking Technology, UEFI BIOS
Manual Settings
CPU frequency, processor core voltage, memory voltage, memory bus frequency
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
ASRock Hybrid Booster, ASRock U-COP, ASRock Instant Boot, NVIDIA SLI Technology Support, ASRock Instant Flash, ASRock CPU Frequency Stepless Control, ASRock Boot Failure Guard (B.F.G.), NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASRock APP Charger, Intel Turbo Boost Technology 2.0, ASRock Good Night LED, ASRock SmartView, ASRock XFast USB, ASRock XFast LAN, NVIDIA 4-way SLI Technology Support, ASRock XFast RAM, ASRock X-FAN, UEFI System Browser, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASRock OMG (Online Management Guard), ASRock Internet Flash, Digi Power Design, AMD 4-way CrossFireX technology support, 24+2 Phase Power Design
I/O back plate, rear USB 3.0 bracket, front USB 3.0 panel, ASRock SLI_Bridge_3S Card
2 x SLI bridge , 1 x 3-way SLI bridge , 6 x Serial ATA cable , 2 x Serial ATA power adapter
Software Included
Drivers & Utilities, Cyberlink MediaEspresso 6.5 (30-day trial), ASRock MAGIX Multimedia Suite
Plug and Play, WHQL, FCC, ACPI 1.1, EuP Ready, ErP Ready
30.5 cm
26.7 cm
