BT.com
Wishlist
ASRock N68C-GS-FX AM3+ AMD NVIDIA GeForce 7025 DDR3 mATX
Delivery
Standard Due date unavailable
ASRock is reaching out to touch the memory lover in every gamer with ASRock unique DDR2/DDR3 combo series motherboards: dual support for DDR2 and DDR3 on the same board. Different from the previous solutions, ASRock combo package allows users to upgrade the existing DDR2 memory to DDR3 effortlessly.
This board is designed to build up the most powerful system and delivers the most demanding technology for users nowadays. Just enjoy next generation computing with ASRock 8-core CPU ready motherboard.
ASRock N68C-GS FX - motherboard - micro ATX - Socket AM3+ - GeForce 7025
Motherboard - micro ATX
Chipset Type
NVIDIA GeForce 7025 / nForce 630a / NVIDIA nForce 630a MCP
Processor Socket
1 x Socket AM3+
Compatible Processors
Athlon 64, Sempron, Phenom II X3, Athlon 64 FX, Athlon 64 X2, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Athlon X2, Phenom FX, Phenom II X4, Phenom II X6 ( Except Phenom II 920 / 940 )
Max RAM Size
8 GB
RAM Supported
4 DIMM slots - DDR2, DDR3 , non-ECC , unbuffered
Storage Ports
4 x SATA-300 (RAID), 1 x ATA-133
USB / FireWire Ports
4 x USB 2.0 + ( 6 x USB 2.0 via headers )
Graphics
NVIDIA GeForce 7025
Max Allocated RAM Size
256 MB
Audio
HD Audio (6-channel)
LAN
Gigabit Ethernet
Chipset Type
Max Bus Speed
1000 MHz
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
8 GB
DDR2, DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 800 MHz, 667 MHz, 533 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
Graphics Controller
NVIDIA GeForce 7025
Memory Allocation Technology
Shared Video Memory (UMA)
256 MB
Audio
Audio Codec
VIA VT1705
High Definition Audio
LAN
Network Controller
Realtek RTL8211CL
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 1 x PCIe x16 , 1 x PCIe x1 , 2 x PCI , 2 x DIMM 240-pin , 2 x DIMM 240-pin
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 0+1 / RAID 5 / JBOD , ATA-133 -connectors: 1 x 40pin IDC - 2 devices
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x VGA , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x microphone - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack
Internal Interfaces
1 x floppy , 1 x audio - 4 pin MPC , 6 x USB 2.0
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
JumperFree, SMBIOS 2.3.1. support, Unlock CPU Core, ACPI 1.1 support, Untied Overclocking Technology
Manual Settings
Processor core voltage, memory voltage, chipset voltage
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
Chassis intrusion detection, ASRock Hybrid Booster, ASRock U-COP, AMD Cool 'n' Quiet Technology, Intelligent Energy Saver, ASRock Instant Boot, ASRock OC Tuner, ASRock OC DNA, ASRock Instant Flash, ASRock CPU Frequency Stepless Control, ASRock Boot Failure Guard (B.F.G.), ASRock AM2 Boost, ASRock APP Charger, ASRock XFast USB, ASRock XFast LAN
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASRock Software Suite
Plug and Play, WHQL, FCC
24.4 cm
20.8 cm
Scroll to top
