BT.com
Wishlist
ASRock N68-GS4U3 GF7025 AM3+ Micro ATX IDE USB3 Serial Port 256MB
Delivery
Standard Due date unavailable
This board is designed to build up the most powerful system and delivers the most demanding technology for users nowadays. Just enjoy next generation computing with ASRock 8-core CPU ready motherboard.
All the capacitors on this board are built with 100% all solid capacitors. With these solid caps, ASRock's motherboards are allowed to perform more stably and ensure longer lifetime.
The technology that allows you to turn on your PC and boot up to Windows in 4 seconds! ASRock Instant Boot not only excels in the Boot Up speed (3~4 sec.), it also provides clean OS, and saves the most power energy.
ASRock N68-GS4/USB3 FX - motherboard - micro ATX - Socket AM3+ - GeForce 7025
Motherboard - micro ATX
Chipset Type
NVIDIA GeForce 7025 / nForce 630a / NVIDIA nForce 630a MCP
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6 (Except Phenom II 920 / 940)
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
4 x SATA-300 (RAID), 1 x ATA-133
USB / FireWire Ports
2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Graphics
NVIDIA GeForce 7025
Max Allocated RAM Size
256 MB
Audio
HD Audio (6-channel)
LAN
Gigabit Ethernet
Chipset Type
Max Bus Speed
1000 MHz
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
Graphics Controller
NVIDIA GeForce 7025
Memory Allocation Technology
Shared Video Memory (UMA)
256 MB
Audio
Audio Codec
Realtek ALC662
High Definition Audio
LAN
Network Controller
Realtek RTL8211E
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 1 x PCIe x16 , 1 x PCIe x1 , 2 x PCI , 2 x DIMM 240-pin
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 0+1 / RAID 5 / JBOD , ATA-133 -connectors: 1 x 40pin IDC - 2 devices
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x VGA , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x microphone - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 2 x USB 3.0
Internal Interfaces
1 x floppy , 1 x parallel
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
ACPI support, JumperFree, SMBIOS 2.3.1. support, ACPI 1.1 support, Untied Overclocking Technology
Manual Settings
Processor core voltage, memory voltage, chipset voltage
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, power supply fan tachometer
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
Chassis intrusion detection, ASRock Hybrid Booster, ASRock U-COP, AMD Cool 'n' Quiet Technology, ASRock Instant Boot, ASRock OC Tuner, 4+1 Phase Power Design, ASRock OC DNA, ASRock Instant Flash, ASRock CPU Frequency Stepless Control, All-Solid Capacitor motherboard Design, ASRock Boot Failure Guard (B.F.G.), ASRock UCC, ASRock APP Charger, Asrock C.C.R. (Combo Cooler Retention Module), ASRock XFast LAN, ASRock XFast RAM, Preboot eXecution Environment (PXE)
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, Antivirus (Trial version), Start8 (30 days trial), Google Chrome Browser, Google ChromeToolbar
Plug and Play, WHQL, FCC, ACPI 1.1, EuP Ready, ErP Ready
Scroll to top
