BT.com
Wishlist
ASRock H81M-ITX Intel LGA1150 H81 mITX DDR3 Gigabit LAN USB 3.0
Delivery
Standard Due date unavailable
This motherboard supports Security Wake On Internet technology with the onboard Qualcomm Atheros LAN, so you can connect with your PC from anywhere in the world. You will be able to power your PC on or turn it off, monitor and take control of it remotely with another smartphone, tablet or computer.
All the capacitors on this board are built with 100% all solid capacitors. With these solid caps, ASRock motherboards are allowed to perform more stably and ensure longer lifetime.
ASRock H81M-ITX - motherboard - mini ITX - LGA1150 Socket - H81
Motherboard - mini ITX
Chipset Type
Intel H81 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Xeon, Core i5, Core i3, Core i7 (supports 4th Generation Intel Core i3 / i5 / i7)
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
2 x SATA-600, 1 x eSATA-600
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 2.0 via headers)
Max Allocated RAM Size
1792 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel H81 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1792 MB
Audio
Audio Codec
Realtek ALC892
High Definition Audio, Premium Blu-ray audio support
LAN
Network Controller
Atheros AR8171
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 2.0 x16
Storage Interfaces
SATA-600 -connectors: 2 x 7pin SATA, 1 x 7pin eSATA - 3 devices
1 x DVI-D , 2 x USB 3.0 , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x SPDIF out , 1 x HDMI , 1 x PS/2 keyboard / mouse
Internal Interfaces
1 x USB 2.0 - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
Multilingual BIOS, SMBIOS 2.3.1. support, ACPI 1.1 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer, opened case detection
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
ASRock Hybrid Booster, ASRock U-COP, 4 Phase Power Design, ASRock Instant Flash, All-Solid Capacitor motherboard Design, ASRock Boot Failure Guard (B.F.G.), Intel Extreme Memory Profile (XMP) support, ASRock APP Charger, Intel Turbo Boost Technology 2.0, ASRock Good Night LED, Intel Clear Video HD Technology, ASRock XFast USB, AsRock On/Off Play Technology, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, ASRock OMG (Online Management Guard), ASRock Internet Flash, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ASRock Dehumidifier Function, ASRock Interactive UEFI, ASRock Fast Boot, ASRock Restart to UEFI, ASRock UEFI System Browser, ASRock Home Cloud, ASRock FAN-Tastic Tuning, Platform Controller Hub (PCH) 1.05V Voltage Multi-adjustment, Platform Controller Hub (PCH) 1.5V Voltage Multi-adjustment, Energy Efficient Ethernet 802.3az, ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, CPU/Chassis Quiet Fan, CPU/Chassis Fan Multi-Speed Control, ASRock A-Tuning
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, Cyberlink MediaEspresso 6.5 (30-day trial), Antivirus (Trial version), Start8 (30 days trial)
WHQL, FCC, ACPI 1.1, EuP Ready, ErP Ready
Scroll to top
