BT.com
Wishlist
ASRock H61M-DGS S1155 Intel H61 DDR3 mATX
Delivery
Standard 3-5 working days
ASRock H61M-DGS features Intel Smart Connect technology, which keeps content always up-to-date! It means that your email, favorite apps, and social networks are continually and automatically updated even when the system is asleep. Smart Connect will periodically wake up the PC while in a sleep state and check updates for things like email, Twitter, Facebook, etc. No more waiting for the latest world news or friends' updates to be delivered - just enable this function and you're up-to-date and ready to go.
ASRock H61M-DGS - motherboard - micro ATX - LGA1155 Socket - H61
Motherboard - micro ATX
Chipset Type
Intel H61 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Core i5, Core i3, Core i7
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
4 x SATA-300
USB / FireWire Ports
6 x USB 2.0 + ( 4 x USB 2.0 via headers )
Graphics
Intel HD Graphics
Max Allocated RAM Size
1760 MB
Audio
HD Audio (6-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel H61 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
Graphics Controller
Intel HD Graphics
Memory Allocation Technology
Dynamic Video Memory Technology 5.0
1760 MB
Audio
Audio Codec
Realtek ALC662
High Definition Audio
LAN
Network Controller
Realtek RTL8111C
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 ( x16 mode ) , 1 x PCIe 2.0 x1
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices
1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x VGA , 1 x DVI-D , 6 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
4 x USB 2.0 - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
JumperFree, SMBIOS 2.3.1. support, Hyper-Threading Technology, ACPI 1.1 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
ASRock Hybrid Booster, ASRock U-COP, ASRock Instant Boot, ASRock Instant Flash, ASRock Boot Failure Guard (B.F.G.), HDCP compliant, Intel Extreme Memory Profile (XMP) support, Solid Capacitor for CPU power, ASRock APP Charger, Intel Turbo Boost Technology 2.0, ASRock Combo Cooler Option (C.C.O), Intel Clear Video HD Technology, ASRock XFast USB, ASRock XFast LAN, ASRock XFast RAM, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video 2.0
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASRock Extreme Tuning Utility, Cyberlink MediaEspresso 6.5 (30-day trial), ASRock MAGIX Multimedia Suite
Plug and Play, WHQL, FCC, RoHS, ACPI 1.1, EuP Ready, ErP Ready
22.6 cm
17.3 cm
Scroll to top
