BT.com
Wishlist
ASRock H110M COMBO-G Intel H110 1151 Micro ATX DDR3 & DDR4
ASRock H110M COMBO-G Intel H110...
£57.38
£57.38
Add to wishlist
Delivery
Standard Due date unavailable
What you've never understood about your computer is that it is scared to death of water, H2O, humidity or whatever you'd like to name it. And even though you do not see the water, actually there may be lots of excessive moist in the air killing your motherboard silently and slowly. No, your motherboard doesn't melt when in contact with water like the wicked witch of the west, but it dies of short circuit.
Luckily, ASRock has a High Density Glass Fabric PCB design that reduces the gaps between the PCB layers to protect the motherboard against electrical shorts caused by humidity.
ASRock H110M Combo-G - motherboard - micro ATX - LGA1151 Socket - H110
Scroll to top
