BT.com
Wishlist
ASRock FM2A88X PRO+ AMD A88X FM2+/FM2 ATX DDR3 CrossFire RAID FM2+
Delivery
Standard Due date unavailable
This motherboard is compatible with AMD FM2+ APUs. ASRock is determined to use high quality materials to build the best motherboards, that's why all the capacitors on this motherboard are built with 100% solid capacitors. These solid capacitors bring long lasting durability and ultra stable performance. This ASRock motherboard supports PCI-E 3.0! PCI Express 3.0 can maximize the bandwidth of the PCI Express 3.0 VGA cards, thus providing ultimate graphics performance. Brilliantly designed for smart overclocking, ASRock X-Boost technology is able to unleash the hidden power of your CPUs. Simply press "X" when turning on the PC, X-Boost will automatically overclock the relative components to get up to 15.77% performance boost! With the smart X-Boost, overclocking CPU can become a near one-button process. Configure different fan speeds for respective temperatures using the graph. The fans will automatically shift to the next speed level when the assigned temperature is met.
ASRock FM2A88X Pro+ - motherboard - ATX - Socket FM2+ - AMD A88X
Motherboard - ATX
Chipset Type
AMD A88X
Processor Socket
1 x Socket FM2+
Compatible Processors
(Maximum TDP 100 Watt)
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
8 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
2 GB
Audio
HD Audio (6-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
AMD A88X
Processor Socket
Socket FM2+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), AMD Memory Profile (AMP)
Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
2 GB
Audio
Audio Codec
Realtek ALC662
High Definition Audio
LAN
Network Controller
Realtek RTL8111G
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 3 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 , 2 x PCI
Storage Interfaces
SATA-600 -connectors: 8 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5
2 x USB 3.0 , 4 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x DVI-D , 1 x VGA , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack
Internal Interfaces
1 x USB 3.0 - header , 2 x USB 2.0 - header , 1 x serial - header , 1 x SPDIF - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
Multilingual BIOS, JumperFree, SMBIOS 2.3.1. support, ACPI 1.1 support, UEFI BIOS, Dual BIOS, Secure Backup UEFI Technology
Manual Settings
Processor core voltage, memory voltage, chipset voltage
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage
Sleep / Wake Up
Wake on LAN (WOL), Atheros Security Wake On Internet Technology
Hardware Features
Chassis intrusion detection, ASRock Hybrid Booster, ASRock U-COP, ASRock Instant Boot, 8+2 Phase Power Design, ASRock Instant Flash, HDCP compliant, Intel Extreme Memory Profile (XMP) support, ASRock APP Charger, ASRock XFast USB, AMD Radeon Dual Graphics, ASRock XFast LAN, ASRock Dr. Debug, ASRock XFast RAM, UEFI System Browser, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASRock OMG (Online Management Guard), ASRock Internet Flash, Digi Power Design, Premium Gold Capacitor design, ASRock Dehumidifier Function, Easy RAID Installer, AMD Steady Video 2.0, ASRock Interactive UEFI, AMD Memory Profile (AMP) support, ASRock Fast Boot, ASRock X-Boost, ASRock Restart to UEFI, ASRock UEFI System Browser, CPU Voltage Multi-adjustment, VCCM Voltage Multi-adjustment, ASRock Home Cloud, ASRock FAN-Tastic Tuning, ASRock Purity Sound, Energy Efficient Ethernet 802.3az, ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, CPU/Chassis Quiet Fan, CPU/Chassis Fan Multi-Speed Control, 4K resolution support, Premium Headset Amplifier, ASRock A-Tuning
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, Cyberlink MediaEspresso 6.5 (30-day trial), Antivirus (Trial version), Start8 (30 days trial)
Plug and Play, WHQL, FCC, EuP Ready, ErP Ready
30.5 cm
18.3 cm
Scroll to top
