BT.com
Wishlist
ASRock FM2A55M AMD FM2 A55 DDR3 mATX
Delivery
Standard Due date unavailable
FM2A55M-DGS: The most cost effective socket FM2 motherboard
  • Support for Socket FM2 100W processors
  • Supports Dual Channel DDR3 2400+(OC)
  • Supports Intel® XMP 1.3/1.2 and AMD Memory Profile
  • Supports AMD Dual Graphics
  • Built-in AMD Radeon HD 7000 series graphics, DX 11, PS 5.0
  • Dual-VGA Output : D-Sub, DVI-D
  • 5.1 CH HD Audio (Realtek ALC662 Audio Codec)
  • Supports ASRock XFast 555, X-Boost, Fast Boot, Restart to UEFI, OMG, Dehumidifier, Easy RAID Installer, Interactive UEFI, AMD Steady Video 2.0
X-Boost
Brilliantly designed for smart overclocking, ASRock X-Boost Technology is able to unleash the hidden power of your CPUs. Simply press "X" when turning on the PC, X-Boost will automatically overclock the relative components to get up to 15.77% performance boost! With the smart X-Boost, overclocking CPU can become a near one-button process.
AMD 2nd Generation A-Series APUs Graphics: Onboard Graphics that break the 3DMark Vantage P7800+ Barrier!
The next generation "Trinity" A-Series APUs provide even more opportunity for tweaking and overclocking, and are better than ever at performing the compute-demanding activities (entertainment, gaming). Supporting AMD Radeon HD 7000 series graphics and DirectX 11 standards, the AMD next-gen A-Series APUs provide 3D gaming experiences similar to discrete-level graphics card solutions. The ASRock FM2 Platform takes advantage of AMD's Trinity APUs, users can overclock the APU to gain further performance. With the powerful integrated graphics, the ASRock FM2 Motherboard Series can deliver 3DMark Vantage (Performance setting) scores of over 7800 points, providing up to 48.92% performance boost.
Fast Boot
With ASRock's exclusive Fast Boot technology, it takes less than 1.5 seconds* to logon to Windows® 8 from a cold boot. No more waiting! The speedy boot will completely change your user experience and behavior. *The boot time may vary with a different configuration.
Support DDR3 2400+
The World's Fastest A55 Motherboard With DDR3 2400+ Support.
AMD Radeon HD 7000 Series Graphics
Engineered for supremacy, designed for efficiency and packed with incredible features, the AMD Radeon HD 7000 Series offers the world's most advanced graphics.
DirectX® 11
DirectX® 11 is the very latest in high-speed, high-fidelity gaming and computing. It can enable not just more visually stunning games, but significant performance improvements in some of your favorite websites and everyday applications.
ASRock - motherboard - Socket FM2
Motherboard
Processor Socket
1 x Socket FM2
RAM Supported
Unbuffered
Motherboard
Processor Socket
Socket FM2
Max Processors Qty
1
Supported RAM
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
High Definition Audio
Power Connectors
24-pin main power connector
BIOS Type
AMI
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage
Scroll to top
