BT.com
Wishlist
ASRock DeskMini 110 mini-STX H110 DDR4 SO-DIMM M.2 Barebone PC
Delivery
Standard Due date unavailable
About Mini-STX
The Mini Socket Technology Extended (Mini-STX) form factor adds the flexibility to support Intel® LGA 1151 socket-based Intel® processors in the mini PC segment
Unique Features
Smaller Size, Better performance
Compared to T-series CPU models, DeskMini 110 uses 65W CPUs and is still smaller than other HTPCs, bringing up to 23% more performance.
Higher Value, Better performance
Compared to U-series CPU models, DeskMini 110 uses Intel standard CPUs that bring up to 21% more performance, while using cost effective Pentium or Core i3 processors.
DC-In Adapter
The DC-In adapter saves users up to 14% on power consumption compared to the traditional PSU design.
Tons of Customization Options
COM port header, TPM 2.0 chip, slim thermal fan or standard Intel box fan. Customize your own mini-STX.
Two M.2 Slots
A key E 2230 M.2 slot for supporting a Wi-Fi + BT module, and another type 2280 M.2 slot which is directly powered by the CPU, thus boasting 7% better performance than other M.2 slots for supporting PCIe Gen3 x4 M.2 SSDs.
SATA type M.2 module is not supported.
USB 3.0 Type-C
A Type-C USB 3.0 connector for fast charging and delivering up to 5Gbps data transfer rates.
Dual Band 802.11ac WiFi
No one has time for weak WiFi signals and sluggish internet! That's why this motherboard comes with a 802.11ac WiFi (2.4G / 5G WiFi) module which supports wireless networks and Bluetooth v4.0.
Available only with DeskMini 110W
Flexible LAN Choice
Settle for the default Intel I219V LAN, or upgrade both your chipset to B150/Q170 and server grade Intel I219LM LAN.
Two SATA3 Headers
There are two SATA3 headers on the opposite side of the motherboard, which supports 2.5" HDDs/SSDs.
Three Graphics Outputs
This motherboard supports all three kinds of graphics D-Sub, HDMI and DP.
Supports up to 2 displays simultaneously
ASRock DeskMini 110 - mini PC - no CPU - 0 GB
PC barebone - mini PC
No CPU
RAM
DDR4 SDRAM
Storage Controller
SATA
Hard Drive
No HDD
Graphics Controller
Intel HD Graphics
GigE
OS Provided
No operating system
8 cm x 15.5 cm x 15.5 cm
PC barebone
Product Form Factor
Mini PC
Processor / Chipset
CPU
No CPU
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel H110 Express
RAM
DDR4 SDRAM
SO-DIMM 260-pin
RAM Supported
32 GB
Hard Drive
No HDD
Storage Controller
SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel HD Graphics
Ethernet Controller
Intel I219-V
Bays
2 (total) / 2 (free) x internal 2.5"
Slots
1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 1 (free) x M.2 Card - 2280 , SO-DIMM 260-pin
2 x USB 3.0 (1 front, 1 rear) , 1 x USB-C 3.0 , 1 x headphones/microphone (1 in front) , 1 x microphone (1 in front) , 1 x HDMI , 1 x DisplayPort , 1 x VGA , 1 x USB 2.0 , 1 x LAN (Gigabit Ethernet)
Serial ATA cable (2 pcs.)
Power adapter
Power Provided
120 Watt
Operating System / Software
OS Provided
No operating system
Software
Drivers & Utilities
8 cm
15.5 cm
15.5 cm
35 °C
Scroll to top
