BT.com
Wishlist
ASRock 990FX Extreme3 AM3+ AMD 990FX DDR3 ATX
ASRock 990FX Extreme3 AM3+ AMD...
£97.16
£97.16
Add to wishlist
Delivery
Standard Due date unavailable
ASRock XFast USB technology redefines the new standard in high performance computing. Proving once again to be the pioneer in motherboard industry, ASRock XFast USB series motherboards integrate with the XFast USB technology which delivers the world's fastest USB data transfer speed. According to the below graph, it shows that the ASRock XFast USB technology can even boost USB 3.0 performance up to 302.99%!
This board is designed to build up the most powerful system and delivers the most demanding technology for users nowadays. Just enjoy next generation computing with ASRock 8-core CPU ready motherboard.
ASRock 990FX Extreme3 - motherboard - ATX - Socket AM3+ - AMD 990FX
Motherboard - ATX
Chipset Type
AMD 990FX / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6 ( Except Phenom II 920 / 940 )
Data Bus Transfer Rate
5.2 GT/s
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
5 x SATA-600 (RAID), 1 x eSATA-600
USB / FireWire Ports
2 x USB 3.0 + 6 x USB 2.0 + ( 6 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Max Bus Speed
2600 MHz
5.2 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1800 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 800 MHz, 1866 MHz, 2100 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC892
High Definition Audio, THX TruStudio Pro
LAN
Network Controller
Broadcom BCM57781
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 2.0 x16 , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
SATA-600 -connectors: 5 x 7pin SATA - 5 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 1 x 7pin external SATA - 1 devices
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 6 x USB 2.0 , 1 x TOSLINK , 1 x SPDIF out , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (front surround) - mini-jack , 1 x microphone - mini-jack
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
JumperFree, SMBIOS 2.3.1. support, ACPI 1.1 support, Untied Overclocking Technology, UEFI BIOS, ASRock Turbo 50, ASRock Turbo 60
Manual Settings
Processor core voltage, memory voltage, chipset voltage
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, power supply fan tachometer
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
ASRock Hybrid Booster, ASRock U-COP, AMD Cool 'n' Quiet Technology, ASRock Instant Boot, NVIDIA SLI Technology Support, 4+1 Phase Power Design, ASRock Instant Flash, ASRock CPU Frequency Stepless Control, ASRock Boot Failure Guard (B.F.G.), NVIDIA Quad SLI Technology Support, ASRock Turbo UCC, ASRock UCC, ASRock APP Charger, ASRock SmartView, ASRock XFast USB, AsRock On/Off Play Technology, Conductive Polymer Capacitors, ASRock XFast LAN, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support
I/O back plate, ASRock SLI_Bridge_2S Card
1 x audio cable
Software Included
Drivers & Utilities, ASRock Software Suite, ASRock Extreme Tuning Utility, Cyberlink MediaEspresso 6.5 (30-day trial), ASRock MAGIX Multimedia Suite
Plug and Play, WHQL, FCC, ACPI 1.1, EuP Ready, ErP Ready
30.5 cm
21.8 cm
Scroll to top
