BT.com
Wishlist
ASRock 970 Pro3 AM3+ AMD 970 DDR3 ATX
Delivery
Standard Due date unavailable
This board is designed to build up the most powerful system and delivers the most demanding technology for users nowadays. Just enjoy next generation computing with ASRock 8-core CPU ready motherboard.
The unique combo cooler retention module greatly improves heat dissipation and is backward compatible with AMD previous AM3/AM2+ coolers. Internet Flash searches for available UEFI firmware updates from ASRock servers.
Fast, easy and free - ASRock OMG technology allows you to establish an Internet curfew or restrict Internet access at specified times. Administrators are able to schedule the starting and ending hours of Internet access granted to other users. Normally, ISPs (Internet Service Provider) will charge for Internet curfew service. The service controls "all" the PCs connected at home through network remotely but all the PCs in that network will be restricted to access the internet at pre-setup times. However, ASRock OMG is a free tool for controlling Internet access of each single PC. Parents can easily control Internet access through BIOS setup to protect their kids from using Internet at inappropriate time, and meanwhile, enjoy their own Internet space.
Even when the system is powered off, on/off play technology still allows users to enjoy the great audio experience from the portable audio devices through the PC speaker. UEFI system browser is a useful tool included in graphical UEFI. It can detect the devices and configurations that users are currently using in their PC. With the UEFI system browser, you can easily examine the current system configuration in UEFI setup. THX TruStudio is specially designed to bring the same great audio experience found in live performances, films, and recording studios to the PC.
ASRock 970 Pro3 - motherboard - ATX no CPU - Socket AM3+ - AMD 970
Motherboard - ATX
No CPU
Chipset Type
AMD 970 / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6 (supports CPUs with up to 8 cores)
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 6 x USB 2.0 + (6 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
No CPU
Chipset Type
AMD 970 / AMD SB950
Max Bus Speed
2.4 GHz
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1800 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 800 MHz, 1866 MHz, 2100 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC892
THX TruStudio PC
LAN
Network Controller
Realtek RTL8111E
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x PCIe 2.0 x16 (x16 mode) , 1 x PCIe 2.0 x16 (x4 mode) , 1 x PCIe 2.0 x1 , 2 x PCI , 4 x DIMM 240-pin
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x PS/2 keyboard , 1 x PS/2 mouse , 6 x USB 2.0 , 2 x USB 3.0
Internal Interfaces
3 x USB 2.0 - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
JumperFree, SMBIOS 2.3.1. support, ACPI 1.1 support, Untied Overclocking Technology
Manual Settings
Processor core voltage, memory voltage, chipset voltage
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, power supply fan tachometer
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
ASRock Hybrid Booster, ASRock U-COP, AMD Cool 'n' Quiet Technology, ASRock Instant Boot, 4+1 Phase Power Design, ASRock Instant Flash, ASRock CPU Frequency Stepless Control, ASRock Boot Failure Guard (B.F.G.), ASRock Turbo UCC, ASRock UCC, ASRock APP Charger, ASRock SmartView, ASRock XFast USB, Asrock C.C.R. (Combo Cooler Retention Module), AsRock On/Off Play Technology, ASRock XFast LAN, ASRock XFast RAM, UEFI System Browser, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, ASRock OMG (Online Management Guard), ASRock Internet Flash
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, AMD OverDrive, ASRock Extreme Tuning Utility, Cyberlink MediaEspresso 6.5 (30-day trial), ASRock MAGIX Multimedia Suite
Plug and Play, WHQL, FCC, EuP Ready, ErP Ready
30.5 cm
20.8 cm
Scroll to top
