BT.com
Wishlist
Aruba HP MSM460 DUAL RADIO 802.11N AP (WW)
Free delivery
Delivery
Standard Due date unavailable
The HPE MSM 802.11n Dual Radio Access Point Series works in unison with the HPE controllers to deliver a high performance WLAN solution. Offering near gigabit client access and increased reliability they are ideal for voice and multi-media communications while providing full compatibility with legacy 802.11 clients and existing HPE wireless controllers. Built-in Spectral Analysis and integrated Wireless IDS/IPS provides detection, classification and intelligent avoidance of non-802.11 interference and comprehensive threat protection. Access points can be deployed in managed or autonomous mode.
HPE MSM460 Dual Radio 802.11n AP (WW) - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
VoIP calls: 12
2 x ceiling mounting clip
Power Over Ethernet (PoE) Supported
PoE
13.2 cm x 15.6 cm x 4.9 cm
330 g
Radio access point
13.2 cm
15.6 cm
4.9 cm
330 g
External
Wireless
Data Transfer Rate
450 Mbps
Remote Management Protocol
SNMP 3, SNMP 2c
Frequency Band
2.4 GHz, 5 GHz
VoIP calls: 12
Auto-uplink (auto MDI/MDI-X), Intrusion Detection System (IDS), Intrusion Prevention System (IPS), IP address filtering, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support
Encryption Algorithm
AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2, MD2
Authentication Method
RADIUS, PAP, CHAP, MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 801.1p, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
6
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
Mounting Kit
Included
FCC Class B certified, EN55022 Class B, ICES-003 Class B, EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15.247, RSS-210, RSS-102, FCC Part 15, MIC, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, EN 301.893, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, RCR STD-33, CSA C22.2 No. 60950-1
PoE
Limited warranty - lifetime
50 °C
5 - 95% (non-condensing)
Accessories
£5.11
£3.87
£12.42
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.90
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£56.20
Scroll to top
