BT.com
Wishlist
Aruba HP E-MSM466 Dual Radio 802.11n Access Point (WW)
Aruba HP E-MSM466 Dual Radio...
£576.48
£576.48
Add to wishlist
Delivery
Standard Due date unavailable
The HPE MSM 802.11n Dual Radio Access Point Series works in unison with the HPE controllers to deliver a high performance WLAN solution. Offering near gigabit client access and increased reliability they are ideal for voice and multi-media communications while providing full compatibility with legacy 802.11 clients and existing HPE wireless controllers. Built-in Spectral Analysis and integrated Wireless IDS/IPS provides detection, classification and intelligent avoidance of non-802.11 interference and comprehensive threat protection. Access points can be deployed in managed or autonomous mode.
HPE MSM466 Dual Radio 802.11n AP (WW) - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
VoIP calls: 12
2 x ceiling mounting clip
Power Over Ethernet (PoE) Supported
PoE
13.2 cm x 15.6 cm x 4.9 cm
330 g
Radio access point
13.2 cm
15.6 cm
4.9 cm
330 g
External
Wireless
Data Transfer Rate
450 Mbps
Remote Management Protocol
SNMP 3, SNMP 2c
Frequency Band
2.4 GHz, 5 GHz
VoIP calls: 12
Auto-uplink (auto MDI/MDI-X), Intrusion Detection System (IDS), Intrusion Prevention System (IPS), IP address filtering, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support
Encryption Algorithm
AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2, MD2
Authentication Method
RADIUS, PAP, CHAP, MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 801.1p, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n
Aerial
Antenna
External detachable
1 x 1000Base-T - RJ-45 , 6 x aerial , 1 x management - RJ-45
Mounting Kit
Included
FCC Class B certified, EN55022 Class B, ICES-003 Class B, EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15.247, RSS-210, RSS-102, FCC Part 15, MIC, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, EN 301.893, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, RCR STD-33, CSA C22.2 No. 60950-1
PoE
Limited warranty - lifetime
50 °C
5 - 95% (non-condensing)
Accessories
£5.16
£3.90
£12.61
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.01
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£57.07
Scroll to top
