BT.com
Wishlist
Aruba HP 501 Wireless Client Bridge
Aruba HP 501 Wireless Client...
£207.07
£207.07
Add to wishlist
Delivery
Standard Due date unavailable
The HP 501 Wireless Client Bridge Series extends life of legacy devices by bridging Ethernet clients to WLAN, extending WLAN access to a range of protocols. Electronic cash registers, medical and manufacturing equipment, and other devices can be deployed in any location with a WLAN signal -saving the time and expense needed for installing Ethernet cables for network access. The HP 501 Wireless Client Bridge Series integrates into the HP Mobility System; and it is interoperable with an IEEE 802.11b/g/n or 802.11a/n/ac WLAN network infrastructure from HP and other vendors.
HPE 501 Wireless Client Bridge - wireless router - 802.11b/g/n/ac - desktop, wall-mountable
Wireless router
Enclosure Type
Desktop, wall-mountable
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP 3, SNMP 2c
Power over Ethernet (PoE), DFS support, half duplex mode, full duplex mode, MIMO technology, Wi-Fi Multimedia (WMM) support, RADIUS support, QoS tagging, DiffServ Code Point (DSCP) support
IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.11d, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e
13.97 cm x 12.7 cm x 3.3 cm
910 g
Wireless router
Enclosure Type
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
TCP/IP
SNMP 3, SNMP 2c
Encryption Algorithm
TLS, PEAP, WPA, WPA2, WEP
Authentication Method
RADIUS, Extensible Authentication Protocol (EAP)
IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.11d, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, EN55022 Class B, ICES-003 Class B, EN 301.489.1, EN 301.489.17, FCC Part 15 B, FCC Part 15.247, OET 65 C, RSS-102, UL 2043, UL 60950-1, EN 60950-1, EN 301.893, FCC Part 15.407, EN 60601-1-2, EN 62311, CAN/CSA C22.2 No. 60950, EN 300 328
Status Indicators
PoE
Serial: 1 x RS-232C , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
3
Directivity
Omni-directional
Gain Level
2 dBi
Software Included
HP Quick Start, HP Intelligent Management Center
13.97 cm
12.7 cm
3.3 cm
910 g
Limited warranty - lifetime - response time: next business day
50 °C
5 - 90%
Scroll to top
