BT.com
Wishlist
Aruba HP 2920-24G 24-port Switch
£1,515.15
£1,515.15
Add to wishlist
Delivery
Standard Due date unavailable
The Aruba 2920 Switch Series provides security, scalability, and ease of use for enterprise edge, SMB and branch office networks. A powerful ProVision ASIC delivers low latency, more packet buffering, and adaptive power consumption. This Basic Layer 3 switch series supports modular stacking, 10GbE, RIP routing, PoE+, ACLs, sFlow, and IPv6. The Aruba 2920 Switch Series delivers consistent wired/wireless user experience with unified management tools such as ClearPass Policy Manager and Airwave Network Management and is ready for Software-defined Networking (SDN) with OpenFlow support.
Aruba 2920-24G - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
20 x 10/100/1000 + 4 x combo Gigabit SFP
Performance
Throughput: 95.2 Mpps , Switching capacity: 128 Gbps
Routing Protocol
RIP, static IP routing
Remote Management Protocol
SNMP 1, RMON 1, Telnet, SNMP 3, SNMP 2c, TFTP, CLI
DoS attack prevention, IPv6 support, half duplex mode, full duplex mode, Class of Service (CoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.1v, IEEE 802.3az, IEEE 802.1AX
44.25 cm x 33.6 cm x 4.45 cm
5.25 kg
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
Routing Protocol
Authentication Method
RADIUS
1 x ARM: 625 MHz
RAM
512 MB SDRAM
Flash Memory
1 GB
24 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x SFP (mini-GBIC) , 1 x management (RS-232) - RJ-45 , 1 x management (mini-USB) - Type B
Expansion Slots
2 (total) / 2 (free) x Expansion Slot , 1 (total) / 1 (free) x Stacking Module
C-Tick, GOST, CISPR 24, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN55024, EN55022 Class A, FCC Part 15 B, ICES-003 Class A, RoHS, IEC 60825-1, EN 60825-1, CAN/CSA C22.2 No. 60950-1-07, IEC 60950-1 Second Edition, VCCI Class A
44.25 cm
33.6 cm
4.45 cm
5.25 kg
55 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£4.95
£3.82
£11.94
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.61
£54.13
Scroll to top
