BT.com
Wishlist
Aruba HP 2530-24G-PoE+-2SFP+ Switch 24 ports Managed desktop, rack-mountable, wall-mountable
Aruba HP 2530-24G-PoE+-2SFP+ Switch...
£1,282.63
£1,282.63
Add to wishlist
Delivery
Standard 1-3 working days
The Aruba 2530 Switch Series provides security, reliability, and ease of use for enterprise edge, branch office, and SMB deployments. Fully managed switches deliver Layer 2 capabilities with optional PoE+, optional 10GbE uplinks, enhanced access security, traffic prioritization, sFlow, IPv6 host support, and power savings with Energy Efficient Ethernet. The Aruba 2530 Switch Series is easy to use and deploy, and delivers consistent wired/wireless user experience with unified management tools such as ClearPass Policy Manager and Airwave Network Management.
Aruba 2530-24G-PoE+-2SFP+ - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 2 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
195 W
Performance
Throughput: 65.4 Mpps , Switching capacity: 88 Gbps
MAC Address Table Size
16000 entries
Jumbo Frame Support
9220 bytes
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH-2, CLI
Flow control, DHCP support, BOOTP support, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, IPv6 support, half duplex mode, full duplex mode, SNTP support, sFlow, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), STP Root Guard, LLDP support, Class of Service (CoS), Generic Attribute Registration Protocol (GARP)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44.3 cm x 33.02 cm x 4.45 cm
3.9 kg
Bundled Services
Enclosure Type
Desktop, rack-mountable, wall-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
195 W
Performance
16000 entries
Jumbo Frame Support
9220 bytes
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1 x ARM: 800 MHz
RAM
256 MB DDR3 SDRAM
Flash Memory
128 MB
24 x 1000Base-T - RJ-45 - PoE+ , 2 x Gigabit / 10Gbit LAN - SFP+ , 1 x console - RJ-45 - management , 1 x USB - Type B - management
Internal power supply
222.2 Watt
FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, EN 60825, CSA C22.2 No. 60950-1
44.3 cm
33.02 cm
4.45 cm
3.9 kg
Limited warranty - advance parts replacement - lifetime
45 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
15 - 90% (non-condensing)
Accessories
£4.95
£3.74
£11.19
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.02
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.63
£50.74
Scroll to top
