BT.com
Wishlist
Aruba 560 Wireless 802.11ac
£832.90
£832.90
Add to wishlist
Delivery
Standard Due date unavailable
The HPE 560 802.11ac Dual Radio Access Point Series brings 1.3 GbE performance, faster application processing and increased range to 802.11 clients. Ideal for dense client environments and high-bandwidth applications, these access points are powered by PoE and offer full compatibility with legacy 802.11 clients and existing HPE wireless controllers. Built-in Spectral Analysis and integrated Wireless IDS/IPS provide detection, classification and intelligent avoidance of non-802.11 interference and comprehensive threat protection. Access points can be deployed in managed or autonomous mode.
HPE 560 (WW) - radio access point
Radio access point
External
1 x 800 MHz
RAM
256 MB
Flash Memory
128 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 16 , VoIP calls: 12
2 x ceiling mounting clip
Power Over Ethernet (PoE) Supported
PoE+
20.32 cm x 17.15 cm x 6.65 cm
1.02 kg
Radio access point
20.32 cm
17.15 cm
6.65 cm
1.02 kg
Processor / Memory / Storage
Processors Installed
1 x 800 MHz
RAM
256 MB
Flash Memory
128 MB
External
Wireless
Remote Management Protocol
SNMP 3, SNMP 2c, HTTPS
Communication Mode
Half-duplex, full-duplex
Frequency Band
2.4 GHz, 5 GHz
Power over Ethernet (PoE), load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), DiffServ support, Intrusion Detection System (IDS), Intrusion Prevention System (IPS), IP address filtering, MIMO technology, Wi-Fi Multimedia (WMM) support, SpectraLink Voice Priority (SVP) support, Quality of Service (QoS), PoE+, ceiling mountable, Wi-Fi Clear Connect, Virtual Service Community (VSC)
Encryption Algorithm
MD5, AES, SSL, TLS, PEAP, TTLS, TKIP, WPA, WPA2, WEP
Authentication Method
RADIUS, PAP, CHAP, MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
6
1 x 1000Base-T - RJ-45 , 1 x serial - RJ-45
FCC Class B certified, ICES-003 Class B, EN 301.489.1, EN 301.489.17, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, FCC Part 15, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC CFR47, EN 301.893, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, RCR STD-33, CSA C22.2 No. 60950-1, iDA, EN 300 328
PoE+
14 Watt
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - phone consulting - lifetime
50 °C
5 - 95% (non-condensing)
Other bundles
£832.90
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£836.38
Scroll to top
