BT.com
Wishlist
Aruba 425 Wireless 802.11n (WW) 8 Pack Access Point
Aruba 425 Wireless 802.11n (WW) 8...
£1,068.33
£1,068.33
Add to wishlist
Delivery
Standard Due date unavailable
The HPE 425 802.11n Dual Radio Access Point Series works in unison with HPE network controllers to deliver a high performance WLAN solution. Offering two spatial stream access and up to 300 Mbps of throughput per radio, they are ideal for voice and multi-media communications and offer embedded high gain and optional external antennas for improved wireless coverage and reliability. Built-in spectral analysis and integrated wireless IDS/IPS provides detection, classification and intelligent avoidance of non-IEEE 802.11 interference and comprehensive threat protection.
HPE 425 (WW) 8 unit Eco-pack - radio access point
Radio access point
Packaged Quantity
8 (specifications are for single item)
External - indoor
1 x 560 MHz
RAM
128 MB
Flash Memory
128 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
2 x ceiling mounting clip
Power Over Ethernet (PoE) Supported
PoE
18.86 cm x 18.86 cm x 5.08 cm
750 g
Packaged Quantity
Radio access point
Ruggedized Design
Indoor
18.86 cm
18.86 cm
5.08 cm
750 g
Processor / Memory / Storage
Processors Installed
1 x 560 MHz
RAM
128 MB
Flash Memory
128 MB
External
Wireless
Data Transfer Rate
300 Mbps
Network / Transport Protocol
DHCP
Remote Management Protocol
SNMP 3, SNMP 2c
Communication Mode
Half-duplex, full-duplex
Frequency Band
2.4 GHz, 5 GHz
DHCP support, VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), DiffServ support, Intrusion Detection System (IDS), wall mountable, Wi-Fi Multimedia (WMM) support, SpectraLink Voice Priority (SVP) support, Quality of Service (QoS), plenum-rated, ceiling mountable, Wi-Fi Clear Connect, Virtual Service Community (VSC)
Encryption Algorithm
AES, SSL, TKIP, WPA, WPA2, WEP
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
4
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 , 1 x management - RJ-45 , 4 x aerial
EN55022 Class B, ICES-003 Class B, EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15 B, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, UL 2043, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC CFR47, EN 301.893, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, RCR STD-33, CAN/CSA C22.2 No. 60950-1, iDA
PoE
External power adapter
Installed Qty
0
Max Supported Qty
1
Software Included
HP Intelligent Management Center, HP Wireless Services Manager
Limited warranty - lifetime - response time: next business day , Technical support - phone consulting - lifetime
45 °C
5 - 95% (non-condensing)
Accessories
£4.95
£3.82
£11.91
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.50
£54.00
Scroll to top
