BT.com
Wishlist
Aruba 215 Instant 802.11ac (WW) Access Point
Aruba 215 Instant 802.11ac (WW)...
£670.52
More than 50 in stock
£670.52
Add to wishlist
Delivery
Standard 1-3 working days
Multifunctional and affordable Aruba 210 series wireless access points (APs) maximize mobile device performance in medium-density, high-performance Wi-Fi environments. These compact and cost-effective dual-radio APs deliver wireless data rates of up to 1.3 Gbps to 5-GHz devices with 802.11ac technology. They also support 3x3 MIMO with three spatial streams as well as 2.4-GHz 802.11n clients at data rates up to 450 Mbps. The IAP-215 models have three integrated omnidirectional down-tilt antennas per radio.
Aruba Instant IAP-215 (RW) - radio access point
Radio access point
In-ceiling - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Mounting brackets
InstantOS
Power Over Ethernet (PoE) Supported
PoE
18 cm x 18 cm x 4.5 cm
610 g
Radio access point
Ruggedized Design
Indoor
18 cm
18 cm
4.5 cm
610 g
In-ceiling
Wireless
Data Transfer Rate
1.3 Gbps
Line Coding Format
CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link activity, power, status, wireless
Auto-sensing per device, auto-uplink (auto MDI/MDI-X), DFS support, reset button, Adaptive Radio Management (ARM), Maximum Ratio Combining (MRC), 3T3R MIMO technology, Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, Energy Efficient Ethernet, Cyclic Delay Diversity (CDD), Space Time Blocking Code (STBC), security lock slot (cable lock sold separately), Advanced Cellular Coexistence (ACC), cyclic shift diversity (CSD)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
6
Directivity
Omni-directional
1 x 1000Base-T (PoE) - RJ-45 , 1 x USB 2.0 - Type A , 1 x console - RJ-45
Mounting brackets
MTBF
538,975 hours
EN 60950, IEC 60950, IEC 60601-1-1, IEC 60601-1-2, UL 60950, CB, EN 300.328, Directive 1999/5/EC, IC, UL 2043, FCC, R&TTE, EN 301.893, EN 60601-1-2, cTUVus, FIPS, LVD, Directive 2006/95/EC, EN 301 489
PoE
13.6 Watt
InstantOS
Limited warranty - lifetime
50 °C
5 - 95% (non-condensing)
Scroll to top
