BT.com
Wishlist
Aruba 205H Instant 802.11ac (WW) Walljack
Aruba 205H Instant 802.11ac (WW)...
£233.86
£233.86
Add to wishlist
Delivery
Standard Due date unavailable
The multifunctional and affordable AP-205H access point (AP) combines high-performance wireless mobility with wired Gigabit Ethernet access in a surprisingly compact device. This compact and cost-effective dual-radio AP easily mounts to a standard data wall-box and uses the existing structured cabling system to provide secure wired and wireless network access in dormitories, classrooms, hotels, medical clinics and multitenant environments.
Capable of delivering high-performance Wi-Fi services to multiple rooms, the 205H simplifies RF coverage planning and reduces WLAN deployment costs. The AP-205H is built to provide years of trouble-free operation. The integrated antennas of the 205H are optimized for the deployments with the AP mounted vertically on either a wall or desk. The antenna patterns are slightly directional, focusing RF energy to and from the area facing the front of the AP. Three local Gigabit Ethernet ports are available to securely attach wired devices to your network. One of these ports is also capable of supplying PoE power to the attached device.
Aruba 205H - radio access point
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Wall plate
Power Over Ethernet (PoE) Supported
PoE
8.6 cm x 4 cm x 15 cm
375 g
Radio access point
Ruggedized Design
Indoor
8.6 cm
4 cm
15 cm
375 g
External
Wireless
Data Transfer Rate
867 Mbps
Line Coding Format
CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link activity, power, status
Auto-sensing per device, auto-uplink (auto MDI/MDI-X), DFS support, wall mountable, Quality of Service (QoS), Trusted Platform Module (TPM), reset button, 2T2R MIMO technology, Adaptive Radio Management (ARM), Maximum Ratio Combining (MRC), Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, Energy Efficient Ethernet, Cyclic Delay Diversity (CDD), Space Time Blocking Code (STBC), security lock slot (cable lock sold separately), Advanced Cellular Coexistence (ACC), ClientMatch, cyclic shift diversity (CSD)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
4
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
Wall plate
MTBF
709,492 hours
EN 60950, IEC 60950, UL 60950, CB, EN 300.328, IC, UL 2043, FCC, R&TTE, EN 301.893, EN 60601-1-2, cTUVus, EN 60601-1, FIPS, Directive 72/23/EEC
PoE
5 - 95% (non-condensing)
Scroll to top
