BT.com
Wishlist
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Arctic Silver Premium Silver Thermal Adhesive
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
When it absolutely needs to stay on forever, Arctic Silver's Premium Silver Thermal Adhesive is the way to go. This permanent epoxy is made with 99.8% pure micronized silver and has a silver content of 62-65% by weight.
Arctic Silver Thermal Adhesive was formulated to conduct heat, not electricity. Even though Arctic Silver Thermal Adhesive is specifically engineered for high electrical resistance, it should be keep away from electrical traces, pins, and leads. The cured adhesive is slightly capacitive and could potentially cause problems if it bridged two close-proximity electrical paths.
PLEASE NOTE: Arctic Silver Premium Silver Thermal Adhesive is a permanent adhesive. Any components you attach together with the Premium Silver Thermal Adhesive will stay attached forever. Arctic Silver Premium Silver Thermal Adhesive IS NOT intended to be used to attach a CPU heatsink to a CPU.
Arctic Silver Premium Silver Thermal Adhesive should be kept cold and away from UV light (sunlight and fluorescent lighting). We recommend refrigerating the unused material and allowing it to come to room temperature prior to use.
  • To be used when there is no other way of securing a heatsink
  • Ideal for small heatsinks, like Northbridge coolers
  • Permanent fixing
  • Made with 99.8% pure micronized silver
  • 62% to 65% silver content by weight
  • Superior thermal conductivity - greater than 7.5 W/mK
Scroll to top
