Click to visit BT.com
BT.com
Wishlist
Arctic Cooling Freezer A30 AMD CPU Cooler (FM2 / FM2+ / FM1 / AM3+ / AM3 / AM2+ / AM2)
4.5*
Quicklinx: 7VKKWS00
Mfr#: UCACO-FA30001-GB
Freezer A30: AMD CPU Cooler for Enthusiasts
The Freezer A30 is an enthusiast-grade 320W CPU Cooler for AMD socket FM2 / FM2+ / FM1 / AM3+ / AM3 / AM2+ / AM2 sockets. With 4 direct-touch heatpipes and an ultra-quiet interchangeable 120 mm PWM fan, this cooler delivers an exceptional cooling performance and amazing silent operation simultaneously.
Main Features
  • Unmatched cooling performance - 320 Watts
  • Ultra quiet interchangeable 120 mm PWM fan installed in a fan holder
  • 4 double-sided direct-touch heatpipes for efficient heat dissipation
  • Flexible 4 directions installation to fulfill different air flow preferences
  • Transport-proof due to sturdy mounting mechanism with metal clips and back-plate
  • Rubber shock absorbers minimize vibration and noise level
  • MX-4 thermal compound included (syringe, 0.5 g)
ARCTIC Freezer A30 - processor cooler
Processor cooler
Package Content
Thermal paste
Compatibility
Socket AM2, Socket AM2+, Socket AM3, Socket AM3+, Socket FM1
Heatsink Material
Aluminium
Fan Diameter
120 mm
Fan Bearing
Fluid dynamic bearing
Rotation Speed
400-1350 rpm
Air Flow
74 cfm
Heat-pipe Direct Touch (H.D.T.) Technology, Pulse-width modulation (PWM) support
13.9 cm x 10 cm x 16.1 cm
0.9 kg
Noise reduction
6 years warranty
Processor cooler
Package Content
Thermal paste
13.9 cm
10 cm
16.1 cm
0.9 kg
Heatsink & Fan
Compatible With
Heatsink Material
Aluminium
Fan Diameter
120 mm
Fan Bearing
Rotation Speed
400-1350 rpm
Air Flow
74 cfm
Rated Current
0.22 A
Noise reduction
6 years warranty
Service & Support Details
Limited warranty - 6 years
Resources
The following resources are available for the Arctic Cooling Freezer A30 AMD CPU Cooler (FM2 / FM2+ / FM1 / AM3+ / AM3 / AM2+ / AM2)
Customer reviews
Write a review for the Arctic Cooling Freezer A30 AMD CPU Cooler (FM2 / FM2+ / FM1 / AM3+ / AM3 / AM2+ / AM2) here!
Nice cooler works well with my AMD am3+ socket
Reviewed by Judygan. Review Posted 11/10/2012
Here are some points i want to share
Installation was relatively fast and simple for me. I am comfortable installing computer hardware.2. Very quiet cooler in my opinion. 3. After installing this cooler, normal temperatures went down from 55º C. to an average of 43º C. This is a huge difference!!4. Here comes the impressive part. Under processor stress, this cooler won't let the temperatures rise above 69º C. No matter what programs I run and how long I run them for. I have been monitoring processor temperatures for the past month with this cooler. I have run several HD video processing jobs. All of them took over 5 hours to complete with processor load at 100%. CPU temperatures have remained steady below 70º C. Very impressive.
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
The performance is really great
Reviewed by Billy. Review Posted 25/10/2012
Installed on a AMD Phenom II X2 555, with all 4 cores unleashed. Other reviewers have mentioned a little tricky to install. But in fact certainly not a difficult install. The cooler came with installation instructions and directs you to the website for other instructions. It is much larger than stock coolers, so you may want to check that you have space for it to fit. No problem in my full size case, but might be tricky in a space saver case. CPU is now running about 3 or 4c cooler on idle (31c), but I have slow running case fans to keep the noise down. With all 4 cores running at 100% (and the case fans turned up), it reached a peak of about 45c, which is a lot cooler than with the stock cooler when running the same tasks it would head to the high 50s.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Best cooler for AMD Athlon II 425 so far
Reviewed by Tyler. Review Posted 18/11/2012
I've recently built an AMD Athlon II 425-based computer. After having already built the computer and using it, the stock fan was a great disappointment. It performed, in my opinion, horribly. At idle the temperature was around 46 degrees Celsius with the fan being noisy. At full load it approached 69 degrees Celsius, which was disturbing enough for me to not set the game in 1080HD display. So I decide to try the ARCTIC A30.
This ARCTIC was an easy installation, no need to remove any components. With the installation complete, I proceeded to the testing of the setup. Because the fan uses a PWM connector, you will have to rely on the BIOS settings to automatically or manually control its RPM.
I was immediately pleased with the idle temp staying at 36 degrees Celsius. I monitored it while it was idle for about an hour observing no change. That is an huge improvement than the stock fan. The fan during this idle period tended to stay quiet. Under full load I was again pleasantly surprised
  • Overall 5*
  • Ease of use 4*
That's great. Compatible with LGA1155
Reviewed by Druant. Review Posted 15/10/2012
I bought this after I realized from reviews of my new i7 processor that I would need a non-stock cooling solution. I have used water cooling on past systems, and ultimately found that these systems just added expense and size to already expensive and large systems. I was encouraged by the price and reviews on this, and was not disappointed. Mounting system is excellent for LGA1155 (my system), and looks equally nice for other compatible boards. I did not run my system without this cooler so I have no comparison, but this keeps the system well under thermal limits even when overclocked. While the stands don't line up with my CPU cutout in my tray, they do fit nicely between the tray and the MOBO. But you will probably need to pull the board, so if you're building a new system make sure you install the mounting hardware for this cooling system before installing your board in the case.
  • Overall 5*
  • Ease of use 4*
WARNING
Reviewed by jeff sylvester. Review Posted 21/02/2012
I put this on a FX8150 in a ASUS M5A97PRO motherboard and it runs hotter than stock cooler!!!
Hits 78-80 and warning temp comes on in BF3.
Its also very large and will not fit into cases with a side fan! you have to take them out.
the freezer pro 13 is much better for AM3+ boards.
system :
FX8150 CPU
CORSAIR 800W PSU
XFX 6970 Graphics
16G RAM
  • Overall 1*
  • Ease of use 3*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
