BT.com
Wishlist
Apple Airport Extreme 802.11
£178.21
20 in stock
£178.21
Add to wishlist
Delivery
Standard 1-3 working days
With three-stream 802.11ac technology, the AirPort Extreme Base Station takes Wi-Fi speeds over the top. You can reach data rates of up to 1.3 Gbps - triple the previous 802.11n standard. Which means up to three times faster Wi-Fi. 2 You also get double the channel bandwidth, with 80 MHz-wide channels providing more room for more data to flow faster than ever. And if you have 802.11 a/b/g/n devices, AirPort Extreme maximizes that connection as well. What you do with all that extra speed is up to you.
AirPort Extreme features simultaneous dual-band 802.11ac Wi-Fi. That means it transmits at both the 2.4 GHz and 5 GHz frequencies at the same time. So no matter which band your wireless devices use, they will automatically connect to the best available band for the fastest possible performance.
Apple AirPort Extreme Base Station - radio access point
Radio access point
External
English / United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
Frequency Band
2.4 GHz, 5 GHz
Connection / user qty: 50
Apple MacOS X 10.2.7 or later, Microsoft Windows Vista SP2, Microsoft Windows XP SP3, Microsoft Windows 7 SP1, Windows 8
AC 120/230 V ( 50/60 Hz )
9.8 cm x 9.8 cm x 16.8 cm
945 g
Radio access point
Built-in Devices
Print server
9.8 cm
9.8 cm
16.8 cm
945 g
External
Wireless
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, Bonjour
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
DHCP support, NAT support, MAC address filtering, IPv6 support, VPN passthrough
Encryption Algorithm
LEAP, TLS, PEAP, TTLS, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
Authentication Method
EAP-FAST
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
Aerial
Antenna
Internal
1 x USB - Type A , 1 x 100Base-TX - RJ-45 ( WAN ) , 3 x 100Base-TX - RJ-45
UL 60950, CSA 22.2 No. 60950, EN 300.328, FCC Part 15 B, RSS-210, AS/NZS 4268, EN 301.893, ARIB STD-T66, RCR STD-33, GB 4943
Internal power supply
35 °C
20 - 80% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.76
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.42
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.05
£15.39
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£29.59
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£20.19
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Scroll to top
