BT.com
Wishlist
APO-G LAMP F SAN-610-323-0726
£180.82
£180.82
Add to wishlist
Delivery
Standard Due date unavailable
The most consumable part of a projector is the projector lamp. When the projector doesn't work, at most cases it is due to the malfunction of the lamp. Actually, components in the projector other than lamp seldom go wrong. If you are satisfied with the brightness and image quality of the projector you are using, it is always good to replace the lamp. APOG can offer you a wide selection of compatible projector lamps that have the same quality as the original lamp under a more "reasonable" and fairer price.
What APOG makes a difference as compared with the original lamp is its own production on the housing and connector which have no direct impact towards the performance of the complete lamp. Although they are relatively subtle, APOG is scrupulous to ensure that the combination of the housing/connection with the original bare lamp achieves the optimal performance.
APO APOG projector lamp
Projector lamp
Eiki LC SB22, XB23, XB27N; Promethean ActivBoard +2; Sanyo PLC SU70, XE40, XU2530c, XU73, XU83, XU84, XU86, XU87
Projector lamp
Eiki LC SB22, XB23, XB27N , Promethean ActivBoard +2 , Sanyo PLC SU70, XE40, XU2530c, XU73, XU83, XU84, XU86, XU87
Scroll to top
