BT.com
Wishlist
Aplix Hook and Loop Cable Tie
Delivery
Standard Due date unavailable
Ideal for use where cables are prone to be added to, moved or removed, the high quality adjustable ties are re-useable and screw mountable. The soft fabric design means a high degree of cable safety - possible cable crushing is minimized.
APLIX Hook & Loop cable tie
Cable tie
Packaged Quantity
25 (specifications are for single item)
0.9 cm
Length
15.2 cm
Packaged Quantity
Cable tie
0.9 cm
Length
15.2 cm
Enclosure Colour
Scroll to top
